Author Subject: oil cooler sandwich plate leak
02woodm
I bought an oil cooler kit from jjc few months ago with a thermostatic sandwich plate
http://www.jjcraceandrally.com/oval/oil-cooler-kits/jjc-oil-cooler-kits-with-free-oil-filter
I fitted it to my project few months ago and I've only just tried running the car up to temperature tonight. Had a small but steady leak coming from that area. Wondering if anyone else has fitted this cooler kit?
Tomorrow night when I get chance i'll have a proper look but i'm sure when I was fitting it I thought it looked floored. It was a few months ago but i'm sure when I tried to tighten the nut up to tighten the sandwich plate in place, it was down in a recess so you couldn't get a socket in very well. Just wondered if anyone else had had trouble with the same kit before I get chance to look at it?
Posted 21st Aug 2013 at 22:44
It probably requires a new seal or you didn't tighten it correctly. Yes
Posted 24th Aug 2013 at 11:07
did you use their supplied bolt or the original pug one?
Posted 24th Aug 2013 at 11:15
Does this leak when the engine is running?
I had an issue with mine whereby it wouldn't leak at all when it was running but once you switched it off it would leak a couple of drops. Sad
Is yours like this or not?
Posted 24th Aug 2013 at 14:38
All these aftermarket units dont have any locating peg so it may well be that the plate moved when the filter last came off.
Posted 24th Aug 2013 at 15:28
What do you mean by 'locating peg'?
Posted 24th Aug 2013 at 16:31
exactly that, a peg to locate its orientation.
Posted 24th Aug 2013 at 17:21
Ok, I know what you mean now. Yes
Posted 24th Aug 2013 at 18:59
