SO, my non returnable new helix clutch is 200mm, will this bolt straight on to gti6 eng/flywheel and be okay!!
I have the old 1.9 gti engine so I got the bits like flywheel off that if need be!
d james
| Author | Subject: 205 gti-6 clutch compatible!! |
daipugralio
Newbie Location: carmarthen Registered: 18 Oct 2012 Posts: 31 Status: Offline |
I bought a helix competition clutch for my 205 1.9 gti with be3 box before I carried out a gti6 conversion, (clutch was never fitted and still in box).. Gti-6 engine was out of rally car and has a be3 box fitted to it with tranx lsd and lower cwp. Clutch feels like it's on the way out and wont adjust much more without peddle being way way above the brake pedal!!SO, my non returnable new helix clutch is 200mm, will this bolt straight on to gti6 eng/flywheel and be okay!! I have the old 1.9 gti engine so I got the bits like flywheel off that if need be! ________________________________________ d james |
no, you need a 215mm clutch and a flywheel with timing teeth for the TDC sensor.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Not very helpful but I'd be interested in your 205 clutch if its a sprung paddle ![]() ________________________________________ www.bridgecraftmotorsport.co.uk |
miles
You could swap over to the 200mm flywheel off a later 306 etc, Mind I;d check what power and torque the clutch is rated at first________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
miles wrote: You could swap over to the 200mm flywheel off a later 306 etc, Mind I;d check what power and torque the clutch is rated at first 200 mm flywheel off a later 306? I thought they was all 215mm? ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Miles means the 1.8 xu7, or late motronic 1.9 205's.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ahh________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
