Author Subject: Misfiring oddly
Roon
Since day dot of having my gti6 205 from cold it misfires a little under light load. It's odd!
What could be causing this?
Having so so so many issues with my car lately!
Posted 10th Aug 2013 at 23:20
It could be a number of things...
Coil pack on it's way out, plugs slightly fouled, CTS not working properly, MAP sensor issue.
What other symptoms do you have?
Posted 11th Aug 2013 at 07:51
Roon
Been like it for 7 months so would have thought a coil would have given up in that time.
What's odd is when i start it from dead cold the rpm sits as it will idle when warm around 850. When it should be around a 1000 surely. Rev it over about 1300-1500 and its happy.
No real other syptoms tbh Stan. Drives well runs over standard power runs perfectly not lean or rich.
Posted 12th Aug 2013 at 13:38
monty-69
Is it fitted with a lightened flywheel?Dunno
Posted 12th Aug 2013 at 14:02
Roon
Nope changed the box and its standard as had thought of that as it revs well.
It's not the end of the world problem but it isn't right and frustrates me Sad
Posted 12th Aug 2013 at 16:10
850 once warm is about right to be honest. Yes
HG *could* be on the way out if it's missing from cold but ok otherwise.
Posted 12th Aug 2013 at 20:04
Roon
What I mean Stan is from cold it idles at 850. I've never had a car or engine do that.
Hopefully not its all been put back together around 7 k ago belt pump and gaskets.
Doesn't touch water or oil at all not in the 7 k miles I've ran it.
Posted 12th Aug 2013 at 22:37
rallyeash
Map sensor? try removing and cleaning see if it helps
309 3dr K20 Type R
Posted 12th Aug 2013 at 22:45
Roon
Ill give that a go. Cleaned it a few months back but could do the trick
Posted 13th Aug 2013 at 11:07
