Author Subject: 6 powered 205 random non-start
mikeygulley
Hi there,
I have an issue with my 6 powered 205.
As a favour to a friend I said I would test 2 of his ECU's on my car, so one evening we arranged to do it. I un plugged my ECU ready for him to turn up, but he didn't so I plugged it back in and headed in doors.
After coming out and expecting to be on my way I turned the key and got a load of clicking from the relay and the fuel pump running constantly. I have had this happen before and it took just minutes to sort after noticing a loose earth so I thought it must be that. Well it wasn't, I have earth checked all earth's and added extra straps.
I have checked that I haven't pushed any pins on the ECU back in and checked lives and switch live on relay, all is well. I also checked voltage at the coil packs and injectors. I have 12 volts on all on the second click of the ignition but less than 1 on cranking. AFAIK this isn't right :/
I have changed the crank sensor also
The relay was tested on my fathers car and it worked but it may have been on it's way out?? (I haven't tested his on mine as I have no access to it at the moment)
The relay now clicks constantly on second click of the key and sometimes needs a tap to run the fuel pump, which is running continuously while the relay continues to click.
Any help would be great, the running of the car has been trouble free for nearly 3 years and the engine has been out and back in in that time too. It is booked in for an MOT tomorrow and I have no other car! It's my daily!! aaaaaahhhhhhhhhhhh!!
Also the chap I was going to help had his ECU's tested and they were locked!! hahahaha!
Many thanks,
Mike
PSCUK Devon & Cornwall Group Leader
devon@pscuk.net or cornwall@pscuk.net
Next meet: TBA
Facebook: click here
Your chances are slim and none.......slim just left!
Posted 9th Aug 2013 at 16:48
Sounds like a dodgy connection on the multi-function relay. Yes
Especially if you have to tap it to make the fuel pump operate. Also, check all fuses.
Posted 9th Aug 2013 at 17:17
mikeygulley
Thanks for the reply.
I have checked them all, I can get it to shut up by removing then re instating the relay while its on. The fuel pump still just continues to run whilst still not even a splutter when cranking, all fuses are fine too. Its a real ball ache for doing something so minor! Hahaha!
Next meet: TBA
Posted 9th Aug 2013 at 18:06
mikeygulley
Found the problem with this earlier. Turns out my ecu has locked somehow! Didn't think it was possible but it happened! :/ hahaha
Now I need one desperatly being my only car at the moment! Hahaha
Next meet: TBA
Posted 16th Aug 2013 at 21:01
How did you come to this conclusion?
Posted 16th Aug 2013 at 22:41
mikeygulley
Well it is only an assumption at this point. A mate popped round with an un locked ecu this evening and it fired straight up. We tried 2 other ecu's last week which turned out to be locked and the same oddeties were happening as when my ecu was plugged in.
Next meet: TBA
Posted 16th Aug 2013 at 22:44
beez_neez_gt
205's starter wire is too thin as standard, they do wear out, it goes from key switch to starter.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 17th Aug 2013 at 02:33
allanallen
This is the problem with 'open' ecu's rather than proper unlocked ones. I've no idea how they lock themselves but I've had it happen twice now.
Facebook
Posted 17th Aug 2013 at 09:25
Yeah, 'soft' unlocked ECU's do have a habit of doing this for some annoying reason. Sad
Posted 17th Aug 2013 at 19:00
mikeygulley
I guess I was lucky to get 3 years out of it! Haha
Next meet: TBA
Posted 18th Aug 2013 at 08:16
I can only imagine the immobiliser wires were not tidied up, no issues with mine after 6 years.
Posted 18th Aug 2013 at 08:28
