Author Subject: effort to start
jimmyhackers
its one problem after another with this car Smile
the car is now sometimes........taking a while cranking over and starts or then starts (poorly) then cuts out.
a bit of throttle helps.
cam sensor on way out? or anything else?
not sure if i have a spare :s is there one on the phase 3 xsi? will it fit in the phase 3 gti?
thaks for the advice
jim
Posted 6th Aug 2013 at 01:50
Check the condition of the plugs.
Posted 6th Aug 2013 at 07:53
No cam sensor on the XSi. No
I'm thinking probably an electrical fault, such as either a bad Earth or battery terminals loose/corroded?
Posted 6th Aug 2013 at 07:55
jimmyhackers
old plugs were fine (good colour) when i replaced them 2 weeks ago. so i dont think its them.
the battery terminals are fine. the earths i havnt checked.....where are they all in the 306? dont wanna miss one by mistake/inexperience
if it was an bad earth wouldnt i experience more "random problems" rather than a specific startup issue?
thanks for the help
jim
Posted 6th Aug 2013 at 16:51
Does fuel pump prime?Dunno
Posted 6th Aug 2013 at 17:01
jimmyhackers
yep it primes :S
Posted 6th Aug 2013 at 17:16
jimmyhackers
problem is still going on. i dont have a new cam sensor in my spares box Sad
where the cheapest place to get a new one?
Posted 10th Aug 2013 at 21:38
JWP EFi
Turbo Legend!
burn it
Posted 10th Aug 2013 at 22:29
jimmyhackers
thnaks for the help so far
right ive fitted a new cam sensor and half the problem is gone.
the engine will turn over and try to fire immediately instead of a few seconds of cranking it over and then it starts fireing.
however upon fireing instantly the first few seconds of running are still... sluggish with it possibly cutting out. after it gets past this it runs fine.
if i try a 2nd cold start (if there is such a thing), i let it run fine for 20 secs then turn it off and on again the issue isnt present.
im thinking fueling and fuel pressure is initialy lacking and taking its time to come through.
ive had a new fuel filter,
so that only leaves, injectors, fuel pump, fuel pressure sensor, fuel pressure regulator....anything else.
anyone got any magical inklings as to which may be the culprit with this new update?
Posted 22nd Aug 2013 at 00:52
Hg
Posted 22nd Aug 2013 at 07:03
jimmyhackers
just to check aboout the head gasket......wouldnt i see my oil or coolant level drop over time?
neithers dropped and ther isnt oil in my water or water in my oil.
also would a hg fault causing my problem dissapear when ive just turned the engine off and on again?
Posted 22nd Aug 2013 at 17:55
If you have a failing HG, you will most likely have coolant seeping into the cylinders when the engine is cold and therefore it will take a while to catch from a cold start as you will need to burn off the moisture first. Yes
However, you would start to slowly see the coolant level going down. If this is the problem then you would have the issue when you run the engine at first, but then if you turn it off and back on again it will have cleared the moisture and the fault would go away.
Posted 22nd Aug 2013 at 18:15
Do you have any pressure in the cooling system after the engine has been sat not running say after 12 hours? If so, that's a classic sign the HG is failing. Sad
Posted 22nd Aug 2013 at 18:16
beez_neez_gt
one person has a funny sense of abuse lol.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 22nd Aug 2013 at 18:25
jimmyhackers
thanks for the help so far. heres an update/recap..... im not loosing water, im not loosing oil
ive changed the map sensor, and the fuel pump relay, fuel pressure regulator. its a new lamdba sensor, new spark plugs, the icv is clean and functioning, i dont have any air leaks on the intake or exhaust.
and ive now come to the conclusion of pants fuel pressure from the pump. its primes but its a very quiet nie on unhearable/unfeelable noise, instead of the usual loud one that virbates the car a bit like in my other 306's
ive asked about a new pump in another thread. not realising i may be able to remove the pump unit itself from the pump housing in the phase3 xsi and put it into the housing on my phase one gti? can i?
Posted 7th Sep 2013 at 16:57
