Author Subject: Reverse cable
Castor_Troy
Hi there in the middle of fitting my compbrake quick shifter only thing im unsure of is how to get the reverse cable holder off im thinking i will just have to get the grinder out and cut down one side then resecure back on with cable ties or hose clips but thought i would check first
Thanks
Posted 5th Aug 2013 at 10:13
superchargedblack1997gti6
don't do it mate it will drive you fcking crazy!
Posted 3rd Sep 2013 at 17:42
fordygti
Push bike brake lever ftw! Thumbs up
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 3rd Sep 2013 at 17:45
yep I know but how do you stop the grub screws loosening off? Mine flaps about like a Bangkok hooker in heatLOL
tempted to just weld the Fcker on there!Thumbs up
Posted 3rd Sep 2013 at 19:09
Niall
tempted to just led the Fcker on there!Thumbs up
Once i decided where i wanted my stick (giggidy) i drilled some dimples where the grub screws sit on the shaft and then locktited the grub screws in. Job done. Never moved!
Posted 3rd Sep 2013 at 18:38
Castor_Troy
I done the same thing and a jubilee clip round plastic housing for reverse cable after cut it off Thumbs up but had to file a bit off so the part you pull up would go down on its own again freely
Posted 3rd Sep 2013 at 21:59
I completely removed hacked to bits and re-fitted mine today at work. Basically I wanted the lever 2" shorter so cut 2" off the top of the lever with an angle grinder. Then you have the problem of the lift up reverse. I then cut off the inner part of the lift up mechanism in exactly te way you were thinking cut a line straight down it, as its stupidly tightly fitted to the lever, cut the the bottom half of it off which holds the outer part of the cable and re fitted it lower down with a jubilee clip round it. Sprayed the lot black (as mine is fully stripped) and refitted the gear nob.
Job done Big grin shorter lever and working lift up reverse that can't slip off. Can add pics If wanted. I also re-fitted my GE quickshift at the same time but not as far down as I had it previously and its a lovely short gear change now that's not to notchy. (With miles rods as well)
Posted 4th Sep 2013 at 01:13
russbez
pretty much what i done iirc
get pictures up Smile
My Rallye project thread
Posted 4th Sep 2013 at 15:48
yes Pete pics please mate want to see how you've done it?
Posted 4th Sep 2013 at 15:59
If I get time I'll take some tomorrow. Thumbs up. Feels a lot better but gotta get used to the shorter stick an shorter throw at the same time. Driving the car to silverstone at the weekend so should give me a chance to get used to it Wink
Posted 5th Sep 2013 at 00:20
Taken loads of pics of what I've done so I'll upload them to photo bucket an start a new thread for an FAQ if others find it useful.
Had to take it all to bits again to get pics so there won't be pics of everything as several parts are cut off or in half now.
Posted 5th Sep 2013 at 14:01
Page for FAQ now done chaps. Have a butchers and tell me what you think. It works a treat I now have an awesome feeling short stick "snigger" LOL
http://www.306gti6.com/forum/showthread.php?id=157275&page=1#2165666
Posted 5th Sep 2013 at 23:57
