displaying posts 26 to 31 of 31
Pages (2): 1 [2]
Author Subject: Head gasket failure!!!
ryangti6
The thing to remember is although the job is quite a bit less than 10 hours hands on time they will have your car sat around in the way with no cylinder head when its being skimmed/tested so most garages will be factoring this in when quoting 'labour' time.
Ryan
Posted 6th Aug 2013 at 18:25
lasooze
It makes a little more sense then.
Black 306 Rallye owner
If you like to read a bit of car geekery, check out this webite run by my other half: http://www.motorcardiaries.co.uk
Posted 6th Aug 2013 at 18:34
10 hours is bo***cks, the Autodata time is 6.8.
Posted 6th Aug 2013 at 19:39
lasooze
Does anyone know where else in the Leeds area I could go where it'd be cheaper?
Posted 6th Aug 2013 at 20:01
mik
I know it is a real downer to have to spend this money but it will be worth it for the future. To that end, I would strongly advise against cutting corners, e.g. missing out the head skim, as without doing it there is a risk the new gasket might not last long if the head isn't true. Definitely do cam belt, water pump and tensioners too, as it is not worth taking a risk with these either.
Ref the labour they are probably adding the cam belt change time (2.7hrs Autodata) onto the 6.8 for head gasket and rounding up to 10, although I would have thought they are taking that stuff off anyway so the cam belt etc would only add half an hour max to it, but I'm not a real mechanic.
Cherry Rallye SOLD
Posted 6th Aug 2013 at 21:02
the 6.8 would include taking the belt off, if they are adding the belt time then they are either cheeky bas**rds or dull as feck.
Posted 6th Aug 2013 at 21:08
Pages (2): 1 [2]
