Author Subject: 406 brembo conversion
Castor_Troy
Hi all just looking for a bit of advise i have a T reg 306 rallye with cyclone wheels looking to convert the brakes i can pick up a set of calipers and carriers from my local breaker for £50 which i though wasn't bad.
The 406 is a 1997 3ltr v6
Was just wondering if they will fit straight onto my 306 and what size of discs i will need
Thanks
Posted 1st Aug 2013 at 16:14
this has been covered possibly once, maybe twice, but most likely 66,170 times before on here
they don't fit under cyclones either
http://www.306gti6.com/forum/showthread.php?id=95186&page=1
Posted 1st Aug 2013 at 16:20
Castor_Troy
I thought they fitted under with 20mm spacers
Posted 1st Aug 2013 at 16:24
Yeah, which is not a clever idea.
Posted 1st Aug 2013 at 16:26
Castor_Troy
Whats wrong with using spacers?
Posted 1st Aug 2013 at 16:30
Puts more loading on the wheel bearings.
Posted 1st Aug 2013 at 16:41
24seven
More importantly, it ruins the steering geometry and you'll probably substitute calliper clearance issues for tyre clearance issues.
Posted 1st Aug 2013 at 17:02
Castor_Troy
Thats what i thought someone might say.
Reading other posts i take it i will need 16" wheels the brembo calipers and carriers then some tarox discs and a decent set of pads
Posted 1st Aug 2013 at 17:10
pugheaven
Isnt Castor Troy the name of the bloke in "Face off" played my Nicholas Cage??
Posted 1st Aug 2013 at 19:43
24seven
Click Yes
Posted 1st Aug 2013 at 19:52
pugheaven
I watch too many films lol
Posted 1st Aug 2013 at 20:04
Castor_Troy
And back on topic lol
just want to make sure i get the right stuff would i be right in saying theses are the discs i need 2 go with the 406 calipers
Years: 5/97 on
Disc Type: Vented
Disc Part Number: 1402
Disc Diameter: 305mm
Disc Thickness: 28mm
Minimum Disc Thickness: 26mm
Offset (Disc Height): 28mm
Centre Bore Diameter: 66mm
Stud Pattern Arrangement: 4
Brake System: BR
Posted 1st Aug 2013 at 22:40
nope, you need 288x28 from a xantia or C5.
Posted 1st Aug 2013 at 22:45
rallyeash
Spend a bit more and get better 4pots that don't squeal and don't need spacers
309 3dr K20 Type R
Posted 1st Aug 2013 at 23:02
Castor_Troy
How much more tho got a limited budget
Posted 1st Aug 2013 at 23:20
JWP EFi
Turbo Legend!
more than £50 i'm afraid, you might be lucky and pick up a set of wilwoods for ~ 300 bucks
Posted 1st Aug 2013 at 23:26
Castor_Troy
would love be able to spend that kind of £ but just cant
Posted 1st Aug 2013 at 23:31
Just buy decent brale pads.
Posted 1st Aug 2013 at 23:35
Castor_Troy
Ha Ha ye but brembo look cooler!
Posted 1st Aug 2013 at 23:50
midlife
http://bit.ly/17SZPgd
End of thread!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 2nd Aug 2013 at 00:45
Castor_Troy
Ha Ha might have been tempted if the silicon glue was included
Posted 2nd Aug 2013 at 08:28
