Author Subject: Annoying noise
02woodm
My rallye has developed a really annoying noise. I don't think it's suspension routed but thought it would be the best place to put it.
The noise sounds as if it's coming from right in front of the driver when your in the drivers seat. To pin point the sound would be on the bulkhead, halfway down.
It is a light knocking sound and it does it every time you lift the throttle pedal, but it doesn't make it when out of gear or with the clutch dipped.
I know this sounds like it would be an engine mount or something making the noise from rocking when you let off, but i'm sure it isn't. It makes it in every gear even if you just rest your foot on the pedal then let it off, so even when no acceleration is applied. I've looked all over underneath and in the engine bay, everything seems rigid and tight.
I recently changed the clutch cabled and it may have got louder since, but that might just be me.
Anyway i'm hoping someone else has had the same noise before and can shed some light, your more than welcome to suggest ideas but I've probably looked at everything you'd suggest.
Posted 31st Jul 2013 at 21:22
top engine mount or cradle cracked or loose.
Posted 31st Jul 2013 at 21:39
02woodm
the rubber, ally and steel of/around the top and bottom engine mount areas all seems good. The bolts are all tight, the rubbers seem to have more play than they should but are not torn or cracked and still hold everything well enough to not allow movement at the steadiness when the noise can occur. Forgot to mention the noise comes about half a second after the pedal is lifted sometimes, sometimes on a bumpy road you can hear it doing it but not often
Posted 31st Jul 2013 at 21:44
This. Yes
Posted 31st Jul 2013 at 22:32
gilesy
Posted 31st Jul 2013 at 22:35
02woodm
I havnt taken the mount off to check the cradle underneath, il do this, thanks
Posted 31st Jul 2013 at 22:36
