Author Subject: abs bleed computer system, what do i need?
jimmyhackers
after a few phonecalls to numerous garages etc etc, the cheapest quote i got to plug in a comp to my abs n bleed it properly was 168 pounds.
so yeah to save myself the hassle, bulls**t n money im gonna get a pug diagnostics of some sort.
i asked before about diagnostics in generall and was suggested the pug planet diagnostics from ebay......
does this do the abs bleeding sequence nonsense??? or do i need somethign different for that???
cheers all
jim
and before ppl tell me otherwise, i let the abs run empty and it defo needs bleeding.
Posted 29th Jul 2013 at 17:19
just bleed the fooker with an eezibleed, that's all I've ever done and never had any problems.
Posted 29th Jul 2013 at 17:50
It does a drip every 10 seconds with the ABS bleed in PP2k. Takes a bloody long time.
Just do a pressure bleed same as everyone else. Then do it again a short time later
Posted 29th Jul 2013 at 19:21
Niall
Yeah as others have said, you can just bleed it with a pressure bleeder. But yeah if you still want it, PP does do bleeding.
Posted 29th Jul 2013 at 23:40
jimmyhackers
thanks for the advice. ill see if i can get my hands on a pressure bleeder kit for free.
do i just connect, pressurize and open my nipples and im away?
what psi should i take the pressure to?
and is their a specific wheel to begin on first asto get most the air out the abs system. or standard further to closest from master cylinder?
Posted 31st Jul 2013 at 00:37
Pressure bleeding is fine but I don't think it will clear air that's locked in the ABS unit.
Most pressure bleeders advise no more than 20 psi in the tyre when doing it. Yes
Posted 31st Jul 2013 at 08:07
I may have this in the mondeo, f**k paying ford £90 an hour to bleed it, If when the pads have bedded back in I still think its not right ill just do the gravel car park thing and rebleed.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 31st Jul 2013 at 13:24
