Author Subject: How do I
ashbash
How can I get my gti6 fans to work with a rallye engine loom.
Any advice please.
Posted 29th Jul 2013 at 13:35
fit rallye fan.
or fit brown sensor into thermostat housing.
do you have the bitron fan control unit?
Posted 29th Jul 2013 at 13:57
The fan wiring/loom is not connected to the engine loom on a rallyeDunno
Posted 29th Jul 2013 at 14:23
i was gonna say is it not just the actual bay loom? i imagine you have the brown sensor plug on the engine loom itself?
Posted 29th Jul 2013 at 14:31
ashbash
The engine come with out a cooling fan switch so I used mine out of my old engine.
Fans kicked in as usual be for I did the swap but now they don't.
Posted 29th Jul 2013 at 15:21
ashbash
Also I know the fans work because if I disconnect the brown plug they both start on low speed then go to high speed.
Posted 29th Jul 2013 at 15:30
so its a 6 with a 6 fan cowling and fans and a bitron fan control unit?
Posted 29th Jul 2013 at 15:39
Probably a loom issue, seeing as that's just been replaced. Yes
Posted 29th Jul 2013 at 19:09
ashbash
Yep all the above I have. The only thing I've done is put the engine in from a rallye along with its loom and I removed everything to do with the a/c
Posted 29th Jul 2013 at 23:56
jimmyhackers
if you have removed your ac you only need one fan.
Posted 30th Jul 2013 at 00:05
sounds like you need a new brown sensor.
Posted 30th Jul 2013 at 00:07
ashbash
I'll have fiddle and see what I can do.
Posted 30th Jul 2013 at 09:11
