Author Subject: Air con
samavery05
I've read the other post on air con but still leaving me a bit clueless...
What pipe breaks? And where is it ? Aprox cos to fix?
Also I don't hear a click and the usuall revs that go up slightly?
Although the light indicates that it's on......
Wouldn't mind it working in this heat wave!!!!
Cheers guys
Sam gti-6
GTI-6.........Gold.
Posted 16th Jul 2013 at 13:16
aaron6
Its the pipes the radiator is low down. They rott at the brackets and cost a bomb to replace. Fill yours up. It may hold charge. Mine did. Smile
Posted 16th Jul 2013 at 13:23
samavery05
Cool.... It is hissing from that location,
Can u explain the reason o can't hear the click or revs?
GTI-6.........Gold.
Posted 16th Jul 2013 at 13:24
pipe behind the bumper with 90degree bend in it,...
yank that s**t out all you need is one of these!
Located to you're Right Thumbs up
Niall
You can't hear it click because the compressor only kicks in when there is enough of a vacuum in th system. If there is no gas, it will ruin the compressor
Posted 16th Jul 2013 at 13:36
samavery05
I see cheers mate, ill look into it
GTI-6.........Gold.
Posted 16th Jul 2013 at 13:45
darkgti6
The pipe that goes you can see come out of the compressor at the back if you peer down between the radiator and inlet manifold. Basically it gets salt on it during winter and it just gets in between the rubber part of the mounting bracket and the pipe and corrodes. It about 90 quid from pug. Factor in new o rings when you remove the bracket on the back of the compressor it holds down both pipes. Also 2 smaller ones where the pipe joins on to the condenser. If your dryer hasnt been changed in the last few years replace that too for about 20 quid from ECP and new o rings there. Pug will supply o rings just look at the exploded diagram for the ones you need. Then get it re gased.
Team Peugeot Sport 308 Gti�
Posted 16th Jul 2013 at 13:55
mattgti6phase2
The compressor will not engage due to low pressure, or any pressure at all if completely empty. Hence the no clicking.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
SmartyC
Ah, that's answered my query, cheers!
Smarty
My lil toy:
http://www.flickr.com/photos/martincurtisphotography/sets/72157640014140786/
Posted 18th Jan 2014 at 14:40
