Author Subject: Non 6 Wheel Query - 206 v 306
cdgray
I know this isn't 6 ralated but basically, looking to know if 1997 306 DTurbo wheels will go straight onto a 2001 206 1.1L?
Mother in laws DTurbo has given up the ghost and she has brought a 206 with steel wheels, so thought it might be worth swapping the wheels over before the DT goes to scrap. In fear of answering my own question, here's what I think are the standards are for both:
206 1.1L: 13x5, offset 28, PCD 4x108, 165/70/R13.
306 DT: 14x6, offset 20, PCD 4x108, 185/65/R14.
I know the overall diameter is bigger on the 306 wheel (595.5mm v 571.2mm) but not sure this would be the issue (other than speedo). Offset not so sure about, would this be an issue? Any thing else to con
Any advice greatly received (need to swap the wheels tomorrow morning if it's ok to do so).
Chris - Phase 3 Moonstone GTi 6
Posted 14th Jul 2013 at 21:14
Itll be fine, you can address the tyre size at a later date, 306 should have been on a 60 not 65 anyway LOL
Posted 14th Jul 2013 at 21:19
ryangti6
As above they will be fine, I put cyclones on my runaround 206 and It's fine, just the front wheels stick out a touch but that won't be a problem on the narrower 14's.
Fyi, Turbo diesel 306's that were on 14's were fitted with a 65 tyre as standard so they aren't wrong
Ryan
Posted 14th Jul 2013 at 21:42
Both mt brothers and myself have had dturbos, all ran 185 60 stock size (according to the sticker that is, mine was on 15"lazers)
Posted 14th Jul 2013 at 22:04
