Author Subject: puddle in drivers footwell
hpgti6
Hi :-( unfortunately I have another problem now
I got in the car today and the drivers footwell is wet and tasted very nasty so
im assuming its coolant.. but no where seems to be wet just in the middle of the padding under the peddles.. have no problems with temperatures when driving but my rad does seem to always be pressurised its a nissens rad but the seal on the cap is split quite bad would this cause the pressure build up...
Also what is the pin located on the picture with the white end on that goes into a hole as this was a little bit wet and very hot :-(
hpgti6 has attached the following image:
Posted 11th Jul 2013 at 21:16
hpgti6
Bigger picture
Posted 11th Jul 2013 at 21:17
rallyeash
Could be Heater matrix
309 3dr K20 Type R
Posted 11th Jul 2013 at 21:29
definitely heater matrix, that's the temperature probe for the AC system.
probably been on its way for a very long time and the HG needs doing as well.
Posted 11th Jul 2013 at 21:33
hpgti6
I do seem to be puttin a bit of water in it only a little but I can see the level keeps dropping but only very slowly.
Oh yeah and most mornings when I start the car I can hear water whooshing from say behind the speedo only for
a couple of seconds if I rev it speeds up but then I dont hear it again . I know it jad a new matrix in 2009 would it go so soon
Posted 11th Jul 2013 at 21:43
blowing HG's do kill off matrix's.
Posted 11th Jul 2013 at 21:45
scotzman
Yes, if your head gasket is on its way out and the system was over preasurised
Posted 11th Jul 2013 at 21:46
hpgti6
Am off to cry in the corner.. spent so much on this car this year already :-( think its going
Posted 11th Jul 2013 at 22:00
Another vote for HG breaking down, causing the matrix to go. Sad
Posted 11th Jul 2013 at 22:26
jimmy_boy
I assume the whooshing water is because air has replaced any coolant that's leaked out. When it starts filling back up you can hear it sloshing about.
Horrible HORRIBLE JOB! Dry
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 11th Jul 2013 at 22:28
hpgti6
Guna be for sale probably put it up tmrw on here for spares and repairs its got a lot of new things on including new clutch and new rear beam from jord
Posted 11th Jul 2013 at 22:59
