Author Subject: brakes still spongy after bleeding
jimmyhackers
having some trouble here
a while ago i replaced my rear calipers because the previous owner had replaced the master cyclinder but snapped the two bleed nipples on the rear calipers. which is why i got it so cheap.
i let the fluid all drain out the system inbetween swapping the rear calipers. ive bled the system 4 times now (2man method). on the last time i got one tiny measly bubble out the rear right.
the brakes are miles better but still spongy. but im not loosing any fluid so i dont think its a leak.
whats the test procedure for brake fault finding? ive seen this guide on the honda forum and am checking if it applies to the gti?
BRAKE BOOSTER INSPECTION
Functional test:
1. With the engine stopped, Depress the brake pedal several times, then depress the pedal hard and hold that pressure for 15 seconds. If the pedal sinks, the master cylinder, brake line or a brake caliper is faulty
2. Start the engine with the pedal depressed. If the pedal sinks slightly, the vacuum booster is working. If the pedal height does not vary, the booster or the check valve is faulty
Leak Test:
1. Depress the brake pedal with the engine running then stop the engine. If the pedal height does not vary while depressed for 30 seconds, the vacuum booster is OK. If the pedal rises, the booster is faulty
2. With the engine stopped, depress the brake pedal several times using normal pressure. When the pedal is first depressed, it should be low. On consecutive applications, the pedal height should gradually rise. If the pedal position does not vary, check the booster check valve.
Check valve test:
1. Disconnect the brake booster vacuum hose at the booster.
2. Start the engine and let it idle. There should be a vacuum available. If no vacuum is available, the check valve is not working correctly. Replace the check valve and retest.
END TEST
and if that fails to come up with anything will it just be old expanding rubber brake lines? will this be a visable expansion?
thanks in advance for your help
jim
Posted 7th Jul 2013 at 00:34
Rubber hoses can expand under pressure, they check them on mot visually when they get the person inside the car to pump the pedalYes
Braided lines do deffo make for a harder pedal, well always have on any car I've fitted them to.
If your pedal does not sink like described in your tests above I would say you have bled them correctlyThumbs up
Posted 7th Jul 2013 at 09:13
JWP EFi
Turbo Legend!
try clamping the flexi hoses just after where they join to the metal pipe, if you instantly get a hard peddle then youve found the problem.
clamp both rears at same time then one by one to find the suspect.
also repeated pumping of the pedal can sometimes cause a seal in the master cylinder to deform which will also give a spongy pedal
Posted 7th Jul 2013 at 10:31
jimmyhackers
this might make me sound silly. but on the vac line theres this t peice valve thing. one goes to inlet manifold one to the brake servo and one to the cam cover.
its...dissasembled itself of sorts/ not air tight.
could this be my problem?
Posted 11th Jul 2013 at 17:53
The fact that you let it run dry when changing the calipers probably means the ABS pump has got air in it, and they are VERY difficult to bleed if they have been left to run dry. Yes
Posted 11th Jul 2013 at 19:08
did you bleed it with rear in the air or on the ground?
Posted 11th Jul 2013 at 19:16
jimmyhackers
my drive slopes downwards. so i place my car facing down it with the front on ramps. this luckily ends up with the car being bang on level when im working on it.
and yes i have let the abs bleed dry. Sad
whats the procedure to bleed the abs? can you link me if theres an FAQ please
cheers
jim
Posted 12th Jul 2013 at 00:17
Search "bleeding ABS system" on Google.
You'll find loads. There are valves within the pump unit that open and shut and you have to move the valves around to let any air escape from within them. Yes
I believe this can be done on Peugeot Planet as well, as the ABS ECU can open the valves when plugged into diagnostics and then you can bleed it successfully.
Posted 12th Jul 2013 at 15:04
Can he not activate the abs pump by shorting a pin/plug or putting a live to it?
I left mine totally drained ages and never had an issue bleeding it after.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 12th Jul 2013 at 17:07
Possibly, although I'm not sure which pins...
Posted 13th Jul 2013 at 09:17
jimmyhackers
lovely, this may seem a silly question then but will an official pug garage still have the electric gizmos to open these valves?
Posted 13th Jul 2013 at 12:45
they should do
Posted 13th Jul 2013 at 14:12
Yes, they should be able to do it just fine. Yes
Posted 13th Jul 2013 at 17:09
Niall
Dont think this is quite true. I was informed by a peugeot master tech that the valves sit open allowing the car to be bled in exactly the same manor as a non abs car. You can however use pug planet for one man bleeding where it just constantly pumps the abs pump. All you have to do is go around cracking off the nipples and keep the MC topped up. Nice and easy!
Posted 16th Jul 2013 at 17:36
that's all I have ever done, other than on load comensator equipped vehicles ensured the valve was positioned as if the rear was loaded (i.e hold the valve open) never had to touch the ABS system in any way when bleeding.
Posted 16th Jul 2013 at 18:38
You shouldn't ever need to worry about the ABS, this is true. However, *if* the system has run dry then it can cause an issue. Yes
Posted 17th Jul 2013 at 10:00
tvrfan007
this is guaranteed to be air in the ABS. I've had it numerous times, though not much on the Peugeot. I was bleeding it and bleeding it and getting nothing but fresh fluid. VAG's let you cycle the ABS as Niall suggests, though I wasn't aware PP did.
When you let the system run dry, as I have done before, you get air trapped in the ABS loop. You will prove this if a double-pump of the pedal results in a significant change in feedback pressure.
The surefire cure is to drive to a gravel car park, mash the brakes numerous times to make the ABS cycle 40-50 times, then drive around for a bit (20 miles or so, braking often). Drive home, and you'll find an air bubble at a bleed nipple - possibly even just one bubble. When I had this with my ex's Rover coupe I must have bled it 15 times all around and was at the end of my tether. After employing this method, I got an air bubble about an inch long at one rear nipple - then the brakes were perfect.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 30th Jul 2013 at 12:37
^^Good advice. Yes
Posted 30th Jul 2013 at 16:48
it is yes but I was wondering if theyre spongy because of the new pads you've fitted that need bedding in?
Posted 30th Jul 2013 at 18:20
tvrfan007
Double pump will highlight the presence of air as the pedal becomes noticeably different.
I'm Si btw Tee hee
Posted 30th Jul 2013 at 19:04
