Am more than happy to change the timing belt and kit , but I have not changed camshafts before and what I want to know is , could there be a chance the camshaft could spin when I slacken the. Timing camshaft pulley bolt?
Cheers mike
| Author | Subject: camshafts |
mike rallye
Seasoned Pro Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
Hi guys I have just brought some up rated camshafts for the six, and what I need help with isAm more than happy to change the timing belt and kit , but I have not changed camshafts before and what I want to know is , could there be a chance the camshaft could spin when I slacken the. Timing camshaft pulley bolt? Cheers mike |
miles
What are the cam's? I take it you have seen what happens if you don't do a dry build with anything with any decent lift________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
I have them and they are only piper 270 so only mild nothing silly lift The cams will move slightly when you take the timing pins out |
stan_306gti6
The cams can 'spring' forwards/backwards when you remove the timing pins as when you pin them up they are on 'rock'. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Project D
Newbie Location: Finland, Turku Registered: 16 May 2012 Posts: 21 Status: Offline |
I installed Newman PH2 cams and idle is now really rough. Should it be like that?Here's video. http://www.youtube.com/watch?v=uWo9pquCpZs |
stan_306gti6
Project D wrote: I installed Newman PH2 cams and idle is now really rough. Should it be like that? Here's video. http://www.youtube.com/watch?v=uWo9pquCpZs Have you had it re-mapped? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Project D
stan_306gti6 wrote: Project D wrote: I installed Newman PH2 cams and idle is now really rough. Should it be like that? Here's video. http://www.youtube.com/watch?v=uWo9pquCpZs Have you had it re-mapped? No. |
have you timed them up properly ? mine idles same as standard with these cams and unmapped.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Project D
I timed them on standard marks/timing. |
get it done properly.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mike rallye
Will the valves not move when the tension comes off the camshafts? And which one do I re time fist inlet or exhaust ? |
stan_306gti6
When the tension is taken off the camshaft, i.e. you remove them the valves will shut.Personally, I would time the exhaust one first, but that's simply because it's he more difficult one to get to as it's at the back. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mike rallye
As there not much real intrest in my cams , am going to fit these within the next month. Is there a chance I could bend the valves when re timing it? |
Hi bud If your not confident doing the cams your self bud ill get it done for you ? I have a top mechanic who has done this job many times ? Get it wrong and kiss good by to the valves ? Contact me if you need help bud |
mike rallye
What sort of price would I be looking at ? |
stan_306gti6
mike rallye wrote: As there not much real intrest in my cams , am going to fit these within the next month. Is there a chance I could bend the valves when re timing it? ![]() If you're not sure what you're doing as Chris says then it's best to pay somebody to do it for you. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
