Author Subject: bias set-up
Is there a set percentage to have going to the rear brakes?Dunno
If I put my car on the mot brake tester and get the figures for the front brakes can I then just set up the bias valve with the rears on the rollers to a certain amount relating to the figure the fronts recorded?
Or is it a case of just testing it driving untill the rear wheels don't lock up under hard braking?
Posted 28th Jun 2013 at 16:14
Personal preference really given its not a load compensator not a rising rate like earlier 306's and ZX's, some people want the rear to move under heavy braking so they can position the car.
There are minimum readings which will be on the computer for the test, so as long as it meets/exceeds that its all good.
Posted 28th Jun 2013 at 16:21
Ok taThumbs up
Just want a safe split, not pretending I'm the stig or nowt with altered brake balance!Smile
Posted 30th Jun 2013 at 12:57
daver6
coskev wrote:
Ok taThumbs up
I might have to do the bias valve setup to sort my compensator. I'd just want a 'safe' setting too
Wishbone Polybushes available
Posted 30th Jun 2013 at 17:07
