Author Subject: Eng loom
On the engine loom there are two multiplugs that connect it to car loom,is one plug for dash related wiring? (Speedo, oil light, temp gauge etc)
And the other plug all related to the engine sensors and ecu?Thumbs up
Or is that wishfull thinking and too obvious for a french car!!Dunno
Posted 27th Jun 2013 at 16:53
this is from the 205 forum in the last few days, for a P-reg gti6, I'm sure ade could get you a more accurate one if you let him know your car's age.
quote:
[quote name="ade 4wd" post="1359165" timestamp="1372263681"]
Peugeot 306 GTI6 engine loom.
23 Pin round connector
1 - Ground
2 - Alternator warning lamp
3 - Reverse switch
4 - Reverse switch
5 - switched 12V
6 -
7 - Tachometer
8 - Starter motor
9 - "K" lamp
10 - Coolant high temp lamp
11 - Coolant gauge
12 - Oil pressure lamp
13 - Diag connector
14 - Oil level gauge
15 - Oil level gauge
16 -
17 - Diag connector
18 - Fuel pump
19 - Oil temp gauge
20 - Speedo
21 -
22 -
23 -
14 Pin round connector
1 - To brown temp sensor on engine if A/C fitted (controls rad fans)
2 - To brown temp sensor on engine if A/C fitted (controls rad fans)
3 - A/C
4 - A/C
5 -
6 - A/C
7 -
8 - Imob
9 - Imob
10 - Imob
11 -
12 -
13 -
14 -
NOTE: There is no constant 12V on either multiplug.
Posted 27th Jun 2013 at 17:04
CheersThumbs up
If fitting itbs I presume you just leave all dash related wiring in the mutiplug, remve all eng related wiring, then attach aftermarket ecu loom into multiplug?Dunno
Posted 27th Jun 2013 at 17:14
That is one way to do it indeed Thumbs up
in reality, very few wires from those plugs actually connect to the ecu as you can see.
Posted 27th Jun 2013 at 18:21
Yeah not many to connectThumbs up
Need to find out if fuel pump wire from DTA goes straight to pump, or is used to switch a relay.
Do you know offhand if VSS live is fed from ECU as standard? If so this will need a +12v sorting.
Posted 27th Jun 2013 at 20:01
that fuel pump wire shown is the feed from the relay, so hook up the dta triggered relay to that.
VSS goes from Sender to ecu and dash, not from ecu.
12v+ IIRC comes from the relay for it, so you can feed that from one of the relays you add in for DTA's injector and coil feeds.
Posted 27th Jun 2013 at 20:07
Injector and coil relays?Dunno
The DTA loom is made up ready, not new, and only wires that need connecting are power, earth, tacho, pump Dunno
But there are no relays anywhere in the loom.
Going to have to download the manual and get my head round itThumbs up
Posted 27th Jun 2013 at 20:25
There should be two relays, one with a switched ignition feed to power the ecu injectors and coil, and a second triggered by the ecu to run the fuel pump.
Posted 27th Jun 2013 at 20:46
Ah I see,cheersThumbs up
Posted 28th Jun 2013 at 11:30
