displaying posts 1 to 25 of 30
Author Subject: gti6 supercharger help!!!!
pete-gti
Hi people for last few months my supercharg 6 has been playing up some times it will just stall on idle or revs will keep going up and down and when driving between 2k and 3k seems to bog then come back to life, I've changed every sensor I can i think off so far. Map sensor, icv, TBS , lamba , coolant sensor, really starting get annoyed hope some one can shed some light on itSmile
Posted 25th Jun 2013 at 13:03
birk
Air leak
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
pete-gti
Alright OK what on the supercharger side? Boost pipes ?
Posted 25th Jun 2013 at 13:04
russbez
hard to say man you would have to check yourself
does it do the dodgy idle when cold??
i had a airleak where my supercharger was welded onto the pipework
was total ball ache idle was awful when car was well warmed up... and intermittently at that!
my top engine mount had crack and caused excessive movement thus cracking the weld at supercharger outlet
used to have a video of it somewhere
My Rallye project thread
Posted 25th Jun 2013 at 13:08
pete-gti
If from cold it will idle fine for about 5minutes then revs will start to move about either going up or try to stall, but it don't always do it, some times when you come to lights it will idle fine, but between to 2k and 3k when around town its starting to splutter , if you put your foot down it clears it, so it could be air leak?
Posted 25th Jun 2013 at 13:14
Same happened to mine, except it was the top mount that came apart somehow, causing it.
Ran awful, and was stalling all over
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Jun 2013 at 13:17
pete-gti
Top engine mount?
Posted 25th Jun 2013 at 13:20
rallyestyle
It could be an air leak, you could try searching for it with some carb cleaner.
I have a similar problem on mine, idle's fine for a few minutes and then starts to stutter a bit. Also hesitates on accleration at certain revs. With an air leak i had always assumed it would stutter from startup rather than after a few minutes?
Did you change all the sensors for new ones?
Changing the MAP improved the problems i was having somewhat but i also think the lambda needs changing, they seem to have both failed around the same time.
Just Drive It
Posted 25th Jun 2013 at 13:25
rallyestyle
pete-gti wrote:
Top engine mount?
Slightly up from where your Supercharger is, where the engine is mounted to the bodywork.
Just Drive It
Posted 25th Jun 2013 at 13:26
russbez
this!!
i cannot remember how i used it (it was 2/3 years ago)
i sprayed it on the suspect joint
rev'd the engine while watching the joint
cannot remember what the result was.... whether i noticed a small discharge from joint or my engine idle changed
dam getting old Yes
Posted 25th Jun 2013 at 13:27
russbez
rallyestyle wrote:
pete-gti wrote:
Top engine mount?
few pictures of top mount on this thread
http://www.306gti6.com/forum/showthread.php?id=123625&page=1
might be worth checking silicone joints too
but if they were damaged or ripped id imagine it would be idle like crap all the time
Posted 25th Jun 2013 at 13:31
pete-gti
Yea I no where it is, but my Mount was changed couple years back, will have look, if you boot it it goes fine, just seems lower down rev range where problems are, really starting to annoy me , some times revs will sit at about 1200 and keep moving up and down, will check all boost pipes and top mount, but I think there fine
Posted 25th Jun 2013 at 13:33
pete-gti
Yea changed for all new dealer sensors, just annoying me so much now spent like 300 on new sensors
Posted 25th Jun 2013 at 13:35
birk
Mine did the same when i had an air leak at the manifold to head join with my ptfe gasket.
07889376885
Dan
Posted 25th Jun 2013 at 14:53
pete-gti
Alright mite look at the air. Inlet manifold then, so all problems I've said that's what you had birk?
Posted 25th Jun 2013 at 15:15
mr west
sounds like air leak as all above say, spray carb cleaner on all intake joins/pipes(one place at a time) when idleing if the revs pick up then that's where your leak is
white rallye
cherry dead rallye
s16
Posted 25th Jun 2013 at 16:18
Moved to Engines. Smile
Posted 25th Jun 2013 at 16:38
pete-gti
OK will check will joints with carb. Cleaner and see what happens, :-)
Posted 25th Jun 2013 at 16:41
If you get stuck come see me next weekend with Aaron6 off here. I can code read the car and have a full set of low boost pipe joiners kicking about. Pete.
Posted 25th Jun 2013 at 20:10
Also I've noticed a considerable improvement in the idle of my supercharged 6 lately. It was forever stalling almost as if the idle valve didn't even try to catch it. Lately only engine related things I've done is change the restrictor ring in the charger for one that's 0.8mm larger and welded up the top engine mount. Also fitted a baker bm lower mount. Don't see how mounts would affect the idle unless the engine was all over the place. Most likely an air leak or dodgy ICV.
Do you have a lightened fly and crank pulley?
Posted 25th Jun 2013 at 20:17
pete-gti
Yea. Got lighter flywheel and crank pully, yea mite stick old icv back in but I'm sure its not that, all mounts where upgraded couple years back so sure it not that, I need to get it plunged in and see if its reading anythik
Posted 26th Jun 2013 at 13:00
Try unplugging the power steering sensor and see what happens. Yes
Posted 26th Jun 2013 at 15:52
pete-gti
Done a proper ecu reset and seems OK but next few days will tell, yea I unplugged the pas sensor revs where still rising slowly and down before I did a reset
Posted 26th Jun 2013 at 18:06
pete-gti
Little update people, I don't think I was doin my ecu reset right , I followed the instructions on here and since then car has been running spot on, took it out for couple hours drive today and didn't miss a beat, idle spot on, so hopefully fingers crossed its solved :-)
Posted 27th Jun 2013 at 15:48
This is good news, let's hope it stays this way. Yes
Posted 27th Jun 2013 at 19:17
