Author Subject: Coolant in the 306 need help!!! is it normal?
Pug bazza
Hello lads, in my 306 1.4 I just noticed something, so want to know if its ok or am doomed, after everything, right my problem is this I was driving the car yesterday, and when I got home I saw dripping from the expansion hose on the radiator, I had been sitting in the 5pm traffic at standstill, and normally the temperature rises, then as I drive it comes back down to 70, when the car cooled down I opened the cap to find only abit of coolant left, so I filled it up with coolant again and started it as the temperature got to 80-85 the expansion hose started to drip again, this morning I filled it up again just a bit as it dropped out the expansion hose last night, drove it this morning and the temperature stayed at round 70, I also had the car jacked up yesterday, and normally when I lift one side of the car up coolant does drip from the expansion hose, could it have been the case of me not spotting the dripping when it was jacked up, don't know just need to put my mind at rest what it could, when its driving the temperature stays at around 70 when it's at stand still it rises and as you drive it cools down back to 70,any advise I'd appriciate
Posted 21st Jun 2013 at 07:26
Fit a new cap, make sure it goes to second potition.
Posted 21st Jun 2013 at 07:37
Pug bazza
Thanks welshpug, do you think that would be problem, and what do you mean by second potition, thanks mate
Posted 21st Jun 2013 at 07:57
The cap should twist a full 180 but its kind of close to the slam panel so sometimes people twist it halfway to avoid pinching their fingers.
Posted 21st Jun 2013 at 08:01
Pug bazza
I always twist it as far as it goes, do you guys think the cap mite be the problem, I did see like brown gritty/scale on the cap and I did wash it out before putting it on again,
Posted 21st Jun 2013 at 08:15
The cap holds the pressure, if the pressure gets higher than the rating for the cap it allows the coolant to bypass and release through the hose.
If the cap is faulty, it will cause a leak at the hose. Yes
Posted 21st Jun 2013 at 09:03
Pug bazza
Thanks guys, new cap will be ordered, thanks guys I do appriciate it
Posted 21st Jun 2013 at 09:23
Pug bazza
I was just fearing the worst, e.g (head gasket) to get a clear Ideas, what would be a symptoms for a head gasket? just for future reference cheers guys
Posted 21st Jun 2013 at 09:35
Pug bazza
How do I find out, what psi my cap holds, as I'm ordering one of eBay and some say 15 psi and some 20 psi and some just come up with 306 radiator cap
Posted 21st Jun 2013 at 11:17
scotzman
I think its 20, just buy it from Peugeot, it wont be expensive and it will be the right one and good quality.
Posted 21st Jun 2013 at 11:27
Pug bazza
Il do that, plus I thought eBay but end of the day best to get quality than quantity, also scotzman or anyone else what are the symptoms for head gasket just got future cheers
Posted 21st Jun 2013 at 11:38
scotzman
Coolant in oil (Mayo in oil filler), Oil in coolant, Steam/white smoke on start up, Misfiring, coolant still pressurised a good few of hours after a run.
Posted 21st Jun 2013 at 11:46
Pug bazza
Thumbs up, got none of them so mine just the cap thanks scotzman, appriciate the help mate Thumbs up
Posted 21st Jun 2013 at 11:50
