Any advice on removing, any potential pitfalls?
What about the wiring and rubber gromet thing?
Any advice/skills much appreicated
| Author | Subject: Swapping boot lids |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
About to go outside and attempt the above.Any advice on removing, any potential pitfalls? What about the wiring and rubber gromet thing? Any advice/skills much appreicated ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Dont do it on your own.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
Haha yeah think that ones a given as I would gave f all change of holidng it steady and tightening it up :p________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
superchargedblack1997gti6
I changed one on my own the other day just put a towel on the boot lip so that you can rest it whilst doing the first bit. take you about half hour if you have a decent buzz gun!________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
russbez
yeh iv also done it with towels alrightwould be a lot easier to use a steady friend getting the rubber grommets in place were a pain iirc ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
How do you remove the rubber gromets to take of the existing one?JUst pull? I assume that theres a connector underneath to disconnect? I also assume its better to remove from the boot end rather than the shell? ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
You need to remove/loosen rear right hand side trim, 3 connectors hidden behind it. Pull rubber out then feed the connectors through one by one, this is a faf and small fingers/patience helps. You'll need to sort the wiper pipe out too which feeds in under the roof lining iirc there is a connector that joins into the boot.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
FML this sound like more of a faf than i thought.Think ill leave it for tomorrow now as im off out at 5 Cheers for that thug ![]() ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
right so ive just started this now, think ive got it all clue up now and sorted (What a faf with all the boot trim though!)Question, New boot has no wiper arm on it. It has the nut attached with a broken bit of plastic, JUst to check, it is a normal lefty lossy righty tighty nut right? ANd not a reverse thread ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
smegal
eliotrw wrote: right so ive just started this now, think ive got it all clue up now and sorted (What a faf with all the boot trim though!) Question, New boot has no wiper arm on it. It has the nut attached with a broken bit of plastic, JUst to check, it is a normal lefty lossy righty tighty nut right? ANd not a reverse thread Yeah, just a normal nut. ________________________________________ Ex SC-6Now in a Megane R26 |
beez_neez_gt
Did u just unplug the wiring from central locking n wiper motor etc then when old boot was off the wiring came out then u fed it back through, or is there a plug link inside the roof lining area like the water pipe?________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
I was just going to re connect the wiring from the new boot, bascially juts what thug said.Anyways, As it turns out i prepped the whole car, removed all the connections and fed them all out and finally was ready to un bolt the old one, Then when i let the new "pretty much mint" boot down on the ground, It had three dings in the bottom of the panel, A chip in the edge and two slight creases along the top edge.So basically not wirth doing. To say i am miffed is an understandment, When i looked at the packaging i realised it wasnt missing the wiper arm at all rather it was led in the bottom of the box snapped. Wasted about 2 hours then.. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
