Author Subject: Front wishbone bolts
gilesy
These bad boys keep undoing themselves slightly, and I keep needing to get back under there and nip them back up.
The cup that they go into in slightly distorted, and as I have roller bearing wishbones, I can't really tighten them up to the recommended torque rating of one white elbow.
Any suggestions? New subframe time? I'm thinking I might go this route
Posted 16th Jun 2013 at 23:37
No reason why they cannot be torqued up properly at all.
Posted 17th Jun 2013 at 00:00
As aboveThumbs up
Can't see what difference a new subframe will makeDunno
Get new bolts and the square nut that is sat in subframe, and if you want peace of mind put some thread lock on themThumbs up
Posted 17th Jun 2013 at 04:48
gilesy
Well I have a 2ft bar and they have previously been done up so tight that it has distorted the cup that the wishbone sits in, to the extent that I couldn't get the washers in for the solid mounts
Think new bolts and thread lock is what's needed.
Posted 17th Jun 2013 at 07:35
daver6
Mine also wound their way out, loctite!
Wishbone Polybushes available
Posted 17th Jun 2013 at 08:47
How did you get on?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 24th Apr 2014 at 16:48
daver6
Well it turns out that mine is now f**ked and needs the bolt and captive nut replaced
Posted 25th Apr 2014 at 18:13
