Author Subject: struggles to start an high idle
robthe6
Had a few problems with the 6 lately. Anyways she's got a running issue. She's a f**ked to start. Lots of cranking with working the throttle. An when she does she's a bit missy at first I think that just due to the poor starting an she idles high like 2200rpm. It's got a new cts an lambda. Changed them both yesterday. Goes well up top but won't idle right or start easily. Iv tried cam sensors too
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 14th Jun 2013 at 14:38
try a new double relay.
Posted 14th Jun 2013 at 15:21
fletch
Track Head
Potentially failing or intermittent crank sensor
Posted 14th Jun 2013 at 15:28
Have you attempted to clean the ICV at all?
To be fair, it sounds like you could have an air leak, which is why it's struggling to start and idling high. When it's idling high, block the air intake to the ICV. The engine should die. If it doesn't you've got an air leak. Yes
Posted 14th Jun 2013 at 15:34
robthe6
Icv was cleaned before but did the finger over the end an it stalled so no air leak. Iv changed double relay an made no difference. I'm currently re cleaning the icv just to make sure. I suspect crank sensor but it gives the correct resistance reading but doesn't mean it can't be intermittent failure
Posted 14th Jun 2013 at 18:09
Strange though if it IS that, as crank sensors usually either work or they don't.
Posted 14th Jun 2013 at 18:56
robthe6
Yeah I do agree but something isn't happy. An short of replacing the icv an crank sensor I have no other way of testing Sad
Posted 14th Jun 2013 at 19:45
robthe6
if she doesn't catch after a min of cranking I have to unplug injectors to get her to start as she floods
Posted 14th Jun 2013 at 23:17
robthe6
Posted 15th Jun 2013 at 18:52
robthe6
fixed! I change the TPS back to an original Peugeot one (cheap ebay one wouldn't keep the plug on properly) it made bugger all difference so got the meter out an did a resistance check on the NEW! CTS and it read something high so check an pair of old ones I had kicking about which said 300 ohms. so plug on of them in an just touched it again the block while it warmed up. the revs started lowering slowly. plugged it back into the new an they jumped. so let the engine cool took the new one out an meter tested it. an it rand 0.9 Meg ohms! when it should be 300 ohms lol. old CTS quick ecu reset an running like a dream again! thank god! was starting to get p**sy with it lol. anyway taking the new sensor back to GSF tomorrow see if I can get it refunded or exchanged.
Posted 16th Jun 2013 at 23:06
Glad to hear she's running sweet again. Thumbs up
Posted 16th Jun 2013 at 23:23
