Author Subject: immobiliser question
bas_306gti
Does the immobiliser cut the power to the fuel pump, or the 12V feed to the injectors/ignition or both ?
Posted 8th Jun 2013 at 18:56
Rich E Forum Admin
Injectors and ignition, but not the fuel pump.
Posted 8th Jun 2013 at 19:01
bas_306gti
So if I have a locked ECU, the fuel pump should run upon startup?
Posted 8th Jun 2013 at 19:08
Yes
Posted 8th Jun 2013 at 19:13
no, given it wont start LOL
Posted 8th Jun 2013 at 19:35
I think he meant starting the ignition switching on process...Laugh
Posted 8th Jun 2013 at 22:12
bas_306gti
Yes I meant not hearing the fuel pump when switching the ignition on.
I don't know if it makes any difference but the engine involved is the XU10J4R engine (306 XSI 2.0 16V) it uses the Bosch motronic MP5.2 ecu.
The ECU seems to be completly dead, there's no spark, no fuel and no 12V feed to the fuel pump.
Posted 9th Jun 2013 at 10:41
Have you checked the fuel cut-off switch and the multi-function relay. Dunno
Posted 9th Jun 2013 at 12:55
bas_306gti
Yes changed the double relay with another one and tested the fuel cut off switch (resistance between pins 0 ohm)
Posted 9th Jun 2013 at 20:09
It does seem like the ECU isn't well, can you try another ECU on yours or perhaps yours on another car?
Posted 9th Jun 2013 at 20:51
bas_306gti
I'm having the ECU tested next week.
Posted 11th Jun 2013 at 21:33
bas_306gti
ECU was unlocked and in good working order.
However I found out that the connector of the crank sensor was switched with the connector of the speed sensor (both 3 pin connectors).
When the ECU does not find the crank sensor during startup (the ECU checks all sensors), the fuel pump is not activated because dual relay is not activated by the ECU Crazy Crazy
Posted 16th Jun 2013 at 18:01
So is it all up and running now then? Dunno
Posted 16th Jun 2013 at 20:41
bas_306gti
Yep, it's running fine now (engine is placed in a 205 Griffe)
I was suprised how easy these connectors can be switched actually,
they are the same 3 pin connectors and are in the same place in the cable loom
Posted 16th Jun 2013 at 21:12
