Team Diesel
| Author | Subject: rocker cover breather gorse. |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
I'm planing on putting a breather filter to the outlet on my oil catch tank instead of running it through the intake. I'm doing this mainly because it causes an annoying oil leak on my boost pipes. Can I do this without causing to much crankcase pressure, or does it need to have vacuum to draw out the pressure? 306 HDi is the car btw. ________________________________________ Team Diesel |
A separator is what you wantStill gets the vacuum draw from inlet, but separates the oil/moisture vapours before they get to inlet. Catch cans without a vacuum draw from inlet are really for race engines only, as a standard/road engine does not get enough blow by past the piston rings to push out crank case gasses/moisture etc. Thread here about the one I've got fitted, works really well http://www.306gti6.com/forum/showthread.php?id=148753 ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
cornish_pug
Mine is a derv though, I thought diesels had quite a lot of blow by?________________________________________ Team Diesel |
only when knackered________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug wrote: Mine is a derv though, I thought diesels had quite a lot of blow by? Abit of diesel oil goes a long way ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
cornish_pug
Over a sustained period I can't imagine it being any good sticking to the aluminium air ways. Good for lubing the bores I guess.________________________________________ Team Diesel |
