Author Subject: Valves 'pop' when opening..?
devere
So I've whipped the head off my engine. I was expecting to see some visible contact marks between valve and piston..
No marks at all, although something has hit somewhere...
On the cylinders that were down on compression, when I move the cams round and open those valves, some of them come down with a 'pop'. Is his a sign of the valve binding in the guide and then coming down when it un sticks itself?
Just looking for some ideas before i take more apart!
Posted 5th Jun 2013 at 09:00
Was this engine a 'tapper'? Dunno
If so, the valves that 'pop' when they open will be the ones that are slightly bent and being forced off their seat when they are not quite square on the seat in the first place.
Posted 5th Jun 2013 at 09:04
I do hope you aren't turning the cams independently?
they will hit each other as there will be a pair open a certain amount all the time.
but as stan said, with strong springs the valves will be forced to seat and the bent ones will spring back to their bent position as they come off the seat.
Posted 5th Jun 2013 at 09:07
The valves ideally need checking by spinning them up to see if they are bent,not much chance of seeing damage by eyeNo
You would have to be a bit dopey to do that with head off!!LOL
Posted 5th Jun 2013 at 09:30
They should slip up and down smooth as a baby's bum, anything other than a perfect sliding fit denotes a problem.
Posted 5th Jun 2013 at 09:43
seems there's plenty of dopey people though Thumbs up
Posted 5th Jun 2013 at 09:55
devere
Ah, I wondered why it went a bit tight.. that's when i got the half inch bar on the pulley bolt and gave it large till they turned. Wink
I made sure that nothing touched. I want to keep as many valves intact as possible!
Surprisingly enough the engine wasn't a tapper. It made no strange noises.. but was down on compression and lost power under full load. Although I guess thats what happens after you change from over 8k rpm in second gear straight into first! Doh!
Posted 5th Jun 2013 at 10:11
The valves may well have been clashing with other valves then instead of valve to piston contact, the gap between my inlets and outlets on overlap is less than 2mm. Maybe that's why you have no witness marks on the pistons themselves?
Posted 5th Jun 2013 at 11:50
devere
Entirely plausible thought that. With the big cans everything is close.
Having looked at the valves as best I can even they don't show clash marks or anything that I would expect to see.
Hopefully its being pulled apart later though so i should find out.
Posted 5th Jun 2013 at 13:06
midlife
The only way you can be sure they aren't bent is to lap them in, you'll never fully lap a bent valve
Cool
Team 330™Cool
Team "no front end or engine"
Posted 5th Jun 2013 at 13:25
Valves are hard as nails, if they were just 'kissing' each other it may not show up visibly at all.
Posted 5th Jun 2013 at 13:55
pop them in a lathe, you'll see the runout if they aren't straight.
Posted 5th Jun 2013 at 14:05
midlife
I put mine in a pillar drill, they all looked good, until I tried lapping them, 2 were ever so slightly out, just enough to make it tap...
Cool
Team 330™Cool
Posted 5th Jun 2013 at 16:32
Exactly, and that's why it's so important on these engines to check each valve for trueness as opposed to just looking by eye. Yes
Posted 5th Jun 2013 at 16:58
devere
Il probably end up doing all 8 in those 2 cylinders that seem to be the culprits.
What involved in fitting new guides to these heads? I haven't had thebpleasure.of that job yet.
Posted 5th Jun 2013 at 17:20
specialist tooling and machinery !
Posted 5th Jun 2013 at 17:50
devere
Hmmm. Il put the lump hammer back in the drawer then.
What's the way of checking the guides then? The engine despite having valve trouble wasn't tapping. So can I take confort in thinking the guides may well be ok..?
I got the head all done before I built the engine, so havent gone vastly in depth to these things yet. So knowing what to look for is a start!
Posted 5th Jun 2013 at 17:57
Fitting guides is an engine shop only job that. Same applies for checking the guides themselves. Take is somewhere good, don't let a monkey touch it.
Posted 5th Jun 2013 at 18:16
To be fair, I'd imagine the guides are good as it wasn't tapping.
However, as Jim says, to be on the safe side take it to a proper engine shop where they have the required tools and know-how to be able to do it properly. Yes
Posted 5th Jun 2013 at 19:54
daver6
Surely the valve guides are seated and removed using a drift? Heating the head will help the removal.
The guides may have a ragged edge or some damage, you *may* be able to ream them, but replacement is the best bet if they were found to be fooked
Wishbone Polybushes available
Posted 5th Jun 2013 at 21:32
They have to be pressed out with the correct mandrel and the head needs well supported if its not to warp or crack. Not a backyard job, it requires precision.
Posted 5th Jun 2013 at 21:42
daver6
Heating the head and tapping the guides out isn't going to crack the head, but I suppose a 'modern' 16v head will want supporting properly, but I can't imagine it being too difficult to sort a jig...
You could even make one up for him Thumbs up
Posted 5th Jun 2013 at 21:44
