£1,000
SOLD
1998 Peugeot 306 Rallye
  • 2000cc
  • Red
  • 98 miles
  • No tax
  • No MOT
  • Some service history
  • Cambelt changed: Jun 2009
Modifications: Throttle body Air filter Stainless exhaust by RTec. Factory Electric Window conversion. New windscreen this spring.
Contact: Matt:
Author Subject: 1998 Peugeot 306 Rallye
singingfish
Time to move my Cherry Rallye on as I know own a fast-ish Seat Leon Deisel.
This car will be sold with these items in the back:
New timing belt kit.
New water pump.
New Rich W Crankshaft pulley (so the timing kit lines up correctly).
Alpine head unit.
set of front wheel arch liners and Arch to bumper under liner thingys.
A replacement Driver door which I sourced a year or two ago on here. (yes it's cherry :-) )
set of all four Rallye branded floor mats.
Reg': S276 FGC if you'd like to HPI it.
This card drives fast and tight but I don't have the time or inclination to nurse it past middle age and into old age now. So . . . . . I'd like it to go into the hands of a club member who'll appreciate its fantastic qualities and look after it.
- The paint is essentially good, though there is a rub on the rear offside quarter/bumper due a neighbour's misjudgement in parking. please refer to pictures for other body condition. Not as faded as most Cherries. A cut and polish will refresh it but I'll leave that to the next owner :-). chip on tailgate needs touching in.
- Interior is all good except for plastic seat lifter toggles and parcel shelf clip going crunchy with age and cracking. these can be had from a breaking 306 or Xsara very cheaply.
-driver side door skirt seal is fubberred. it's silly the way these disintegrate. they don't actually do much except catch your heel when you get in and out tbh.
- Steering wheel has a bit of rim wear, all done by previous vice gripping drivers wringing the wheel.
There is a strip of rust on the bottom edge of the driver door. This is why I got the replacement door some time ago but I never got to fitting it.
- I will bundle in the Alpine head unit with dash adaptor surround in the boot with the sale but no speakers are included.
- no boot liner carpet included. unfortunately a can of oil saw off this beyond cleaning so I got rid.
- upholstry: The drivers seat has wear which you can see in the pics, but it's not in the usual place in the side bolster. Crazy. the rest is in good shape.
- under the bonnet:
I have cambelt receiptsfrom before I owned the car so the belt I'm supplying will be its second change. (I fibbed in the cambelt change box as it doesn't date back that far).
I replaced the Aux belt and tension rollers in April this year. I was going to replace the included cambelt at the same time but this work was held up by the need for new crank pulley (high quality RichW Jobbie included in the sale)
I bought this car in 2009 on VERY LOW MILEAGE. The seller and I thought the car had stood idle for a long time as the mileage was really low.
This car isn't a tapper but does have one tappet which can be heard.
Car pulls strongly, has all that superb throttle response we know and love and idles perfectly.
It is time for an oil and coolant change.
The car uses a little oil and I've been advised that this is due to valve guide oil seals needing replacement.
I've always wanted a head strip and rebuild for this car but just never got to it or had the money at the right time.
compression is good, as is everything else. So I'm confident the oil is seeping through valve seals.
I fitted new thermostat and housing this year as the old one got tired and wouldn't let the engine reach running temp as fast as it should have.
gearbox is A1.
- Running gear:
Rear Brake Discs are due replacement due to not being worn correctly because of sticking caliper sliders.
Rear Brake calipers in need of servicing or replacement because of sticky sliders. Not an expensive fix.
Usual wear and tear to rubber suspension and anti roll bushes, wishbones. these aren't knackered but should be refreshed at some point to keep everything sweet. roller bearing 'P' bushes and urethane bushes might be a nice idea at this point.
Wheels and Tyres are all in good nick. couple of kerb marks but rims were refurbed in 2009 and tyres were new all round last year. - good Toyo T1Rs which suit the car perfectly.
car tracks perfectly.
PM me if you have any other questions or would like me to add anything here I might have left out.
This is a great car and needs an owner who'll keep it that way.
My partner and I thought long and hard about investing in it to own it indefinitely but the lure of a reliable VAG Derv car was too much so I have to let this great car go. It's my third 6/Rally and fourth 306 so I've learned the way these cars drive and what to fix and when, so hopefully I can answer any questions you have.
singingfish has attached the following image:
defected to VAG
Faithful Rallye looking for a home.
[sniffs]
Posted 19th Jun 2013 at 21:49
singingfish
rear quarter rub
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:46
singingfish
great tyres and wheels. bumper grille needs a little tlc when included arch liners get fitted.
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:47
singingfish
defected to VAG
[sniffs]
singingfish
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:48
singingfish
defected to VAG
[sniffs]
singingfish
low mileage.
60,000 of these miles done by me since 2009.
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:49
singingfish
already I'm missing this car.
driving it onto the field to take photos, I wanted to go and hoon in down the B road. :-D
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:50
singingfish
The reason I'm selling this car this cheaply for a car on this mileage is that I'm leaving the work to the buyer rather than investing the time and effort myself.
I think that this car will be a great buy for the right person who I'd hope would be a Rally enthusiast.
The parts I'm including in the sale are worth a significant amount whch makes this a great deal.
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 08:57
mik
Super deal - £1000 for a clean-looking Rallye! Cheapest non-FUBARed one I've seen.
Cherry Rallye SOLD
Posted 5th Jun 2013 at 17:33
singingfish
amen brother
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 18:01
jimmyrallye
Eddy get ya euros out fella
Posted 5th Jun 2013 at 18:10
cheinikas
Is it still for sale? How can I contact You?
Posted 5th Jun 2013 at 18:26
singingfish
just PM me dude.
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 18:54
Rich E Forum Admin
He's not a member Matt, so doesn't have a mailbox!
Posted 5th Jun 2013 at 19:19
singingfish
oh..
i see
i didn't think non members could post.
but they can in the for sale forum yes?
Doh!
defected to VAG
[sniffs]
Posted 5th Jun 2013 at 19:42
singingfish
okay:
Email me on Singingfish@ntlworld.com
defected to VAG
[sniffs]
eddy_gti6
I had my name all over this till the bellend who wone my clio on ebay p**sed me about!!! Gutted Sad
Good luck with the sale mate Thumbs up
Posted 6th Jun 2013 at 00:32
singingfish
Yoou still have a sshout on it if you can get finances together Eddie ;-)
defected to VAG
[sniffs]
Posted 6th Jun 2013 at 09:23
arigti6
Billy Bargain. GLWTS!
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 6th Jun 2013 at 16:34
singingfish
cheers.
defected to VAG
[sniffs]
Posted 7th Jun 2013 at 08:08
singingfish
come on all.
my Rallye is too good to let go longer without a club owner.
defected to VAG
[sniffs]
Posted 11th Jun 2013 at 20:00
ry
Hi mate.
How much oil do you tend to go through with the valve stem/seat seals say every 1000 miles?
Does the tappet noise die down once warmed up?
And are you certain it would be the callipers that need refurbishing along with the brake discs on the back?
Looking to get a 2nd car whilst I sort out some engine work on mine so this may be ideal.
Ry
Turbocharged Honda Integra Type R DC2
Posted 11th Jun 2013 at 20:28
singingfish
ry wrote:
Hi mate.
Ry
it doesn't use lots but I think it leaks into the exhaust side and gets heated out in the exhaust. no smoke at all.
the tappet noise isn't bad. sounds like a lazy valve lifter to me.
performance is great though.
the calipers and copper brake lines need attention on the back. the sliders may be freeable. the discs have uneven wear and the calipers drag. left rear mostly.
306 rear brakes are pants really. good job the front setup works so well on these cars. I had the same problem with an HDi back in 2001 I remember.
come and have a look at it matey.
defected to VAG
[sniffs]
Posted 11th Jun 2013 at 23:53
