| Author | Subject: Ditching ABS |
JWP EFi
what bits do i need to bin the abs pump? |
2 T pieces, roll of copper pipe, some pipe fittings and a bias valve if your binning compensator too________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
JWP EFi
so basically just tee each wheel off? Iv'e binned compensators on my last 2 6's and never had an issuethis is a 2001 so doesn't have beam mounted compensator |
Rich E
That suggests there's been something wrong with the rear brakes on your previous cars.If you don't do something to sort the bias then you'll get 50/50 distribution so you should be able to lock the rears easily under heavy braking, which is quite bad from a safety perspective, especially if removing the ABS. ________________________________________ Rich |
JWP EFi
i see what your saying but my ph2 6 has new rear calipers and i replaced master cylinder too, the brakes are great yet ive never had the rears lock up even in the wetI may just fit a bias valve on this one though |
Rich E
On a phase 3 you can simulate the effects of this by unplugging the ABS. This will kill the EBD and give you 50/50 distribution.Take it out for a drive and if you can't feel the difference in brake force distribution or can't get the rears to lock then something is wrong somewhere. Obviously do this carefully though! ________________________________________ Rich |
eddy_gti6
Or buy my full braided brake line kit with bias and fluid included ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
JWP EFi
was waiting for that one chris, you'll need it for your next investment no?? |
eddy_gti6
I have no use for them mate. Next car is going to have mint condition complete recaro interior as you have seen.________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
