Author Subject: GTI-6 engine block - from what other is compatible?
edhunter
Hi all,
My engine has failed - broken piston + hole in the block.
I need to know - is the gti-6's engine block same as on the others 2 liter XU engines?
Thanks in advance
Posted 26th May 2013 at 17:03
I know it's not the question but I don't think the pistons are the same due to the higher compression.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th May 2013 at 18:37
Think its the same block from the s16 and possibely late mi16 ? Maybe the 2.0 xsi as well ? Sure welsh pug can shed more light
Posted 26th May 2013 at 18:46
We can send a gti6 block out to Bulgaria if needed ?
Posted 26th May 2013 at 18:47
Posted 26th May 2013 at 19:01
The block is the same as the XU10J4R engine, but the pistons are unique to the XU10J4RS (GTi-6) engine.
Some XU10J4R blocks come with the piston oil spray bars, some do not, it depends which vehicle the engine was originally intended for. However, the spray bars are simple to fit if the engine you find doesn't come with them.
Therefore, you're best off looking for a replacement engine of the same type, as Bowen says he can supply an engine to Bulgaria for you. Smile
Posted 27th May 2013 at 10:22
edhunter
Thank you all.
Today I've removed engine head - it is damaged too.
The piston has been deep in the head. Even the spark plug hole on the top is smashed.
It seems that I will need whole engine.
@bigbadbowen can you make an offer for engine delivered to Bulgaria Smile in PM if you prefer.
Posted 27th May 2013 at 21:59
