Author Subject: Later style cam pulleys
24seven
Does anyone know the part number and/or price for the later style camshaft pulley with the single bolt? Servicebox pictures the earlier style with the part number "0805 66" and says that it's NFP. Also are the central timing "hubs" the same for both styles of pulley? Think one of the earlier style ones on my engine has shat itself.
thanks in advance!
Posted 24th May 2013 at 21:41
JWP EFi
Turbo Legend!
ive got numerous sets you can have for a small fee
Posted 24th May 2013 at 21:50
Rich E Forum Admin
0805 A3 for the later style cam pulley, £19.99 + VAT each RRP
0805 82 for the timing hubs, £5.62 + VAT each RRP and they are the same on both cams on the '6, but unique to the type of pulley.
There's a phase 3 VIN here if you need to look up later parts on service box but can't find them easily on the full view.
edit: I also have a pair of later style ones going spare if you want them... Whistle
Posted 24th May 2013 at 21:52
Shows pulley as:
0805 A3
ENGINE CAMSHAFT GEAR
42 DENTS
And pinion:
0805 82
PINION HUB
BE- - BLUE
Pulley showing as £23.99,pinion as £6.74.
Pulley is way cheaper than I expected!Shock
Posted 24th May 2013 at 21:54
And pinion hubs are different for each type of pulleyYes
Posted 24th May 2013 at 21:56
24seven
Great, thanks folks. Are the camshafts the same on the ends where the pulleys & hubs attach, or cn I "upgrade" to the later style without issue?
PM on its way, thanks.
Posted 25th May 2013 at 09:07
Rich E Forum Admin
Yep, direct fit.
Posted 25th May 2013 at 09:12
24seven
Happy days! Thanks again!
Posted 25th May 2013 at 09:21
I take it the ones that rich w cracked were the old style ones?
Posted 25th May 2013 at 16:30
The older styles ones have been known to crack around the M6 bolt holes, hence the reason they were changed by Peugeot. Yes
Posted 26th May 2013 at 12:04
