Author Subject: Inner tie rod removal
cornish_pug
Hello!
I will be looking to change the nearside inner tie rod this weekend and I've noticed on the new part there is no hex for a spanner.
Is there enough room down there to put a set of mulgrips on it?
Thanks in advance.
Team Diesel
Posted 22nd May 2013 at 17:54
honestly3k
What brand did you buy?
Ive just had inner and outer tie rod/ends fitted, they were lemforder and had the hex part of the shaft on for easy removal.
I wouldn't have thought there was much room down there.
Chance it could be seized too so goodluck
Posted 22nd May 2013 at 18:15
cornish_pug
Delphi, looks pretty good quality mind you. I'll be using something called gas plus to break the thread free its far better than WD40.
Team Diesel
Posted 22nd May 2013 at 18:37
as its all sealed under a boot I have yet to have the inner thread seize, they wind out by hand after the initial loosening.
Posted 22nd May 2013 at 18:46
pooouk
Take the wishbone off and it's a piece of p**s after that. I lay under mine for half an hour trying to do it with the wishbone in place (using a small set of stilsons), took the wishbone off and it was done ten minutes later!!
Nick
AKA nick on 205gtidrivers.com
Posted 22nd May 2013 at 19:57
JWP EFi
Turbo Legend!
big set of vice/mole grips is my weapon of choice, they aren't that tight, don't have to take lower arm off but does help a bit, i usually put a dab of Loctite on the threads when fitting new one.
Posted 22nd May 2013 at 20:39
