Author Subject: oil cooler kit
Time has come to somehow squeeze a 16 row ideally oil cooler on the front of my supercharged 6 somewhere. After a thermostatic plate plus oil lines and ideally 16 row cooler. See what anyone's got going before I fork out for a new one.
Posted 21st May 2013 at 22:25
I've got a brand new thermostatic plate that I'll not be using, yours for £35+postage. Also, would you like some brackets welded onto your FMIC like I did to my LBSC6?
As you can see from the pictures the bumper requires some fairly comprehensive trimming. If you send me your FMIC and order your cooler to be delivered to me I can supply the mounting bobbins so it all fits correctly.
Posted 22nd May 2013 at 09:49
rallyeash
Got a stat Take off plate spare
309 3dr K20 Type R
Posted 22nd May 2013 at 19:08
bazgtmi
Got a complete kit here!
205Parts@uk7.net
Posted 24th May 2013 at 19:49
Looks top work Davey but am after a complete kit really, also my inter cooler is welded to the front slam panel so can't really send it to you. Want the cooler to sit to the right of the inter cooler as well.
How much for complete kit delivered? Also is the plate thermostatic? Pics please.
Posted 24th May 2013 at 20:33
How is your alloy cooler welded to a steel slam panel?
Posted 24th May 2013 at 20:55
aaron6
I just thought that. LOL
Posted 25th May 2013 at 11:07
playboyb
playboyb has attached the following image:
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 25th May 2013 at 11:41
It can be done, Audi for one use a mig process for welding ally to steel but its not something I'd expect to see done on a Peugeot.
Posted 25th May 2013 at 11:52
Ask lynx they did it! Lol. I'm Intreagued now actually. It's nut and bolted to the lower slam panel but the two coolers are welded to brackets which are welde to the top slam panel. Having a proper look means taking bumper and grille off again which I'm not doing till I fit the cooler.
Posted 25th May 2013 at 20:48
Ally wont be welded to the steel, there will be brackets you can't see or something.
Posted 25th May 2013 at 21:29
smegal
The oil cooler bracket is bolted to the I/C. I made that part. Lynx then welded that to the slam panel, so it should come apart.
Ex SC-6
Now in a Megane R26
Posted 25th May 2013 at 22:12
I can't remember mate just know it all came off your car hole and was welded to the slam panel. I don't need to take it off anyway as there's room on the O/S for an oil cooler to go between the IC and fog light. Now I think about it I've got pics from when I fitted it Wink. But no sig at the gf's to upload from phone. IC bolted to steel brackets holding SC cooler which are welded to top slam panel.
Posted 26th May 2013 at 00:18
Bumpy
Sent Baz a pm but no reply...
Posted 28th May 2013 at 13:52
rallyeash
Got pipe work and thermostat take off and adaptor plate spare ready to roll. Just need a rad
309 3dr K20 Type R
Posted 28th May 2013 at 13:57
Hmmmm it it rubber pipe work or braided and is it thermostatic? Have just ordered a new seal for behind the cooler as mine has sprung a leak anyway. And will be removing the standard heat exchanger.
Posted 28th May 2013 at 14:02
rallyeash
Proper hydraulic pipe work, so braided inner with a rubber outer and crimp on 1/2 bsp fittings. Yes it's w thermostatic sandwich plate
309 3dr K20 Type R
Posted 28th May 2013 at 16:43
How much you after chap?
Posted 30th May 2013 at 00:06
No one wants to sell anything then? Dunno
Posted 2nd Jun 2013 at 23:51
rallyeash
been away the weekend, but 30 delivered?
the pipes arent over long though, about 12"
309 3dr K20 Type R
Posted 3rd Jun 2013 at 09:34
I've managed to grab a full 16 row satreb / mocal kit with lengthy hoses brand new on eBay for cheap. Not sure if plate is thermostatic or not yet. If if isn't I'll have it off you Wink
Posted 4th Jun 2013 at 22:57
