Author Subject: measuring ball joints
greenie
Fellas,
How do I determine which ball joints I should be buying ?
There seems to be various different sizes available.
Thanks in advance.
Posted 20th May 2013 at 19:57
birk
Undo your ball joint and look lol
16mm or 18mm Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 20th May 2013 at 20:05
greenie
Is it that simple Unsure
I thought they differed in other ways depending if you had PAS or not.
Great if its that cut and dry, I can definitely measure things.
Posted 20th May 2013 at 20:24
birk
They changed the ball joint size on the facelift cars, but most cars have been messed around with, so your car may not have the correct hubs on.
But either way, just undo the ball joint, drop the wishbone down and have a butchers Smile
07889376885
Dan
Posted 20th May 2013 at 21:06
greenie
Yeah you are absolutely right, thats what I will have to do.
I was hoping to go and buy before I dismantle, but its not going to happen.
Thanks for the help.
Posted 20th May 2013 at 21:09
honestly3k
I'd drop your driver side balljoint out.
Dropping the passenger side will almost certainly result in the driveshaft popping out of the gearbox and spilling gearbox oil all over your driveway
Speaking from experience LOL
If yours is a R-reg then most likely 16mm balljoints but I'd check to be sure
Posted 20th May 2013 at 21:27
greenie
MMm, point noted, thanks.
I am changing the ball joints as I have roller P bushes coming and new shocks.
Ie, hubs off and wishbones coming out so I will have to be really careful of the oil issue.
Thanks for the heads up.
Posted 20th May 2013 at 21:39
I have a spare set of 16mm ball joints ? Lemforder oe spec no bolts just the joints ?
Posted 20th May 2013 at 21:48
honestly3k
If I were you I'd have some box oil on standby incase you need it, I did, was lucky LOL
greenie
Good to know thanks.
I will be in touch as soon as I know what I need.
How much do you want for them, by the way.
Posted 20th May 2013 at 21:50
birk
And a gearbox seal Smile
07889376885
Dan
Posted 21st May 2013 at 09:12
