Author Subject: Brake pad rattle?
tomlum
Hi all, whenever I go over pot holes or even slightly rough road I get a rattle from the front? This completley goes away with just the slightest pressure on the brake pedal, which make me believe its the pads at the front? Ive had the wheel off and the pad will move in the caliper if you prod it. What is going on here?
Thanks for any advice, Tom
Posted 20th May 2013 at 13:58
are they fitted correctly?
Posted 20th May 2013 at 15:55
tomlum
I have no idea as ive not touched them before, maybe I should take them out and re-fit them. Is there anything I should look for that could be missing? Springs..clips?
Posted 20th May 2013 at 16:30
springs are attached to the pads, my feeling would be more towards wheel bearings.
Posted 20th May 2013 at 16:31
Niall
Ive had two callipers now where the sliders have worn and the calliper has rattled on the carrier. Take the wheel off and see if you can move the calliper about at all. If so, new sliders time.
Posted 20th May 2013 at 16:52
tomlum
But would the rattle stop with pressure on the brake pedal if it were wheel bearings?
Posted 20th May 2013 at 17:53
Depends of the rattle only occurs at a certain speed and whether you pushing the brake is taking it out if that area
Posted 23rd May 2013 at 21:56
