Author Subject: Please help, running problems
braymond
A few weeks back, the car started to run poorly. Hesitant under anything more 30% throttle, spluttering and missing, and unable to develop usual power.
In my mnd it felt like it was getting too much/not enough air or fuel (and t also seemed to coincde with filling up with Shell Vpower ntro stuff).
So anyway, I got through that fuel, and topped up with something known. I also changed the fuel filter, all to no avail, but when I changed the plugs (which all looked ok and the same as each other) it seemed to fix it.
Delighted, of course, but a few days on, its once again running not quite rght. Only at low rpm now, and whislt drivng normally or even pressing on its fine. ut around town, its hesitant and spluttery once again.
Any thoughts?? Its been on a diagnostics and nothing obvious shows up. A mechancic friend feels (but can't be sure) thats its an injector issue.
Any thoughts welcome..
Rallye-R
Nurburgring article
Posted 18th May 2013 at 14:41
Coil pack failing ?
Doubt it's an injector ?
Tps or Icv ? May be worth changing them and the coils for known good ones Yes
Posted 18th May 2013 at 15:32
mike rallye
Would the tps cause idle issue to?
Posted 18th May 2013 at 15:42
braymond
bigbadbowen wrote:
Coil pack failing ?
Certainly worth a go. Odd that it ran fine for a few days though.
I've put up a post in the wanted for a set of coilpacks, thanks
Rallye-R
Nurburgring article
Posted 18th May 2013 at 15:49
aaron6
That makes me think coil packs.
Posted 18th May 2013 at 18:12
aaron6
Poor earth maybe? Its worth a look as its free.
braymond
How what where do I check?
Rallye-R
Nurburgring article
Posted 18th May 2013 at 19:31
Coil pack breaking down or lambda on the way out. Yes
Posted 18th May 2013 at 21:12
mattgti6phase2
Lambda? Mine would run fine then it would produce no power then it would come back again then sometimes it wouldn't do it at all. Then I discovered the lambda loom had broken wires so because i haven't had time to fix it yet i run without it plugged in and it's absolutely fine just bigger flames LOL
Jut unplug it and see how you get on Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 19th May 2013 at 10:07
braymond
Where is it?
Rallye-R
Nurburgring article
Posted 19th May 2013 at 11:02
mattgti6phase2
The loom runs from the back of the ECU and then clips on to the bulkhead. At that point you will see a square plug with a red top, pull the red top upwards and this will release the lambda.
Let us know how you get on Smile
5 x a 306 owner!
Posted 19th May 2013 at 14:57
aaron6
Theres a faq on tue earths iirc. If not check some threads and you'll find it easy enough. Smile
Posted 19th May 2013 at 17:54
mattgti6phase2
Just to bump this thread guys i have finally got hold of a xsara VTS lambda loom.
Are they the same? It seems the red and green are the opposite way round on the VTS loom, will this cause problems if i follow red to red green to green?
5 x a 306 owner!
Posted 20th Aug 2013 at 19:18
I believe they are the same Matt, not sure if they changed the loom across VTS phases though...
Posted 20th Aug 2013 at 23:29
mattgti6phase2
Well I've connected it red to red green to green etc and it seems to be running fine so I'm guessing its correct. The car is no quicker or slower but the major thing i have noticed is it doesn't smell anywhere near as rich as what it did which will hopefully improve my MPG Smile
5 x a 306 owner!
Posted 21st Aug 2013 at 08:44
Sounds like you've sorted it then mate. Thumbs up
Posted 21st Aug 2013 at 08:53
mattgti6phase2
I will get my mate to put it on diag so i can actually see it reading. Will do an ecu reset today as i haven't done this since connecting it back up.
5 x a 306 owner!
Posted 21st Aug 2013 at 08:57
Yeah, that's probably a good idea although if the rich smell has gone that's got to be a bonus. Smile
It smelt rather 'fuely' at Pugfest. Yes
Posted 21st Aug 2013 at 09:59
mattgti6phase2
So can anybody tell me which wire does what? When the car idles from start up it'll randomly pick the revs up and drop them back down again just the once. So I'm interested in what they do if anybody knows??
Many thanks.
5 x a 306 owner!
Posted 21st Aug 2013 at 18:39
The 4 wires will be power, signal, heater and Earth but in what order I'm unsure.
What colours do you have and I'll take an educated guess...
Posted 21st Aug 2013 at 19:24
