Author Subject: weird electric window and battery light issue
Hi my freinds gti6 has developed two problems at exactly the same time, while driving the battery light came on and the windows stopped working, 1 is stuck in the down position, the car starts fine, I've yet to check it with a multimeter but I'm now convinced it could be linked, would the wiring in the door pillar in the rubber sleeve of cut through and be shorting out somehow causing the battery light to come on and both fail to work?
Im Not sure where to start with this one.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th May 2013 at 22:44
Sounds like the door loom is in trouble and also the alternator is not charging the battery. Two separate things. Check the battery voltage when the car is running would be my first port of call mate.
Posted 18th May 2013 at 08:37
I thought that, It's just strange it happened together
Posted 18th May 2013 at 11:22
It was just fuse no 28
Posted 19th May 2013 at 17:16
Excellent, good to know it was an easy fix. Hopefully, there's not an underlying issue which caused to fuse to blow in the first place.
Posted 19th May 2013 at 20:09
Yes its the Rear wiper motor I believe
Posted 20th May 2013 at 08:47
Ah, that makes sense. Yes
Water ingress usually is the culprit for that one.
Posted 21st May 2013 at 05:26
