Author Subject: What's behind the rear view mirror? Can the wiring be remove
Tallguy_2
Quick question that I've tried searching for but can't find an answer.
What is the wiring for that runs up to behind the rear view mirror? Can this be cut and removed? It comes out and runs down the a pillar.
Just a quick curious question
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 17th May 2013 at 18:39
pugheaven
It's for the rain sensitive sensor,lights and sunroof if you got one!
No need to cut it just disconnect the plug under the dash (drivers side under the fuse box)
Posted 17th May 2013 at 18:44
Tallguy_2
Won't stop the car from running then lol!
Does the whole bit unstuck then?
Posted 17th May 2013 at 18:51
I seem to remember my wipers refused to work with the rain sensor unplugged. It can all come off the windscreen, but the two metal brackets that hold the rain sensor are stuck on with some sort of adhesive, you can get them off though if you get a fine blade under them.
In my track car i have the rain sensor sat inside the dash on a shortened loom, allows the wipers to work on the various settings except the actual sensing position, where the wipers have a mind of their own and wipe at random. LOL
Posted 17th May 2013 at 19:00
Niall
Iirc if the sensor is removed, it reverts to intermittent wipe.
Posted 17th May 2013 at 20:37
pugheaven
No it doesn't, first click nothing second normal speed and third nothing so really you have one speed and that's it
Posted 17th May 2013 at 21:52
Niall
Ah i thought it did. Maybe its if the sensor packs up, it reverts to intermittent?
Posted 17th May 2013 at 21:53
Tallguy_2
Thanks boys, all sorted, no wiring running round now!
Like you say ollie when unplugged you have one speed.
The unit in mine literally just unclipped off the screen, I then just wound it up and tucked the unit up under the dash for now so that everything still works like you said prism7guy
Cheers!
Posted 17th May 2013 at 22:36
