Author Subject: running extra gauges(volts and oil temp)
7057sam
Hi guys
I have recently bought 2 52mm gauges volts and oil temp
Question is :what or how do I run them?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 14th May 2013 at 23:45
fatlapit
Instructions shud be in box but gti has oil temp n wats the point in volts?? Let me guess ure gonna mount them in a crap pillar mount??
Posted 14th May 2013 at 23:47
Volt guage needs a permanent live (via a shareable fuse 2,3 amp should be fine) and an earth, if its illuminated too you'll need to find a wire that is live when your lights are on, a courtesy light from anything behind the dash should do fine for this.
Is your oil temp guage electrical or mechanical?
Posted 14th May 2013 at 23:50
I'd be more interested in oil pressure myself.
Posted 14th May 2013 at 23:51
7057sam
Sorry fatlip its not fast and furious
Davey I had a quick read somewhere not here, that for the volts you can split the stereo 12 volt?
The oil is mechanical do I need a sender?
Rallye dead Sad
Posted 15th May 2013 at 00:19
fatlapit
U need some form of take off from an oil take off n run a capilary tube to back of guage mate
Posted 15th May 2013 at 00:33
Hmmm hot pressurised oil behind the dash? I think I'd want an isolator, check Merlin motor sports or similar for something to keep hot oil away from you if a pipe fails.
Posted 15th May 2013 at 00:45
Why are you fitting an oil temp gauge? There is one already on the dash cluster as standard. Blink
Posted 15th May 2013 at 06:58
JWP EFi
Turbo Legend!
yes but how accurate are they?
as said above, i would have got a pressure gauge-vital engine diagnostic tool imo
Posted 15th May 2013 at 07:46
anth
I ran my volt meter from the battery itself.
Would also opt for a pressure gauge to be honest (I did) far less p**sing around and more useful.
In terms of lighting them up I took a feed from the heater knobs and soldered small wires to circuit board, that way you can control the whole lot on the dimmer switch.
These days i would just pay someone to do it, f**k all that nonsense Big grin
Posted 15th May 2013 at 07:52
as accurate as an aftermarket gauge, and as accurate as you needs it to be.
Posted 15th May 2013 at 10:59
Exactly, I have fitted an oil PRESSURE gauge in mine, but the factory fit oil temp is very accurate I find. Yes
Posted 15th May 2013 at 11:41
