Author Subject: vacum pump ...oil leak
spiky
I seem to have a small oil leak around the rear of the vacum pump,
now, i've never removed this or know whats behind it, am i right in thinging it is connected the cam and so there will be oil behind it, and is the cause of my oil leak?
if so can i get a gasket? or should i just use some sealent on this?
or is it possible my cam cover thats leaking?
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 14th May 2013 at 19:35
There's only 2 6mm Allen bolts that hold it on iirc. There's a rubber o ring round the pump that seals it. This may need replacing but I'd just chuck some sealant round there and be done with it but cam covers leak as well.
Posted 14th May 2013 at 19:40
spiky
ok cheers, sounds simple enough Smile
MY YouTube Videos'
Also yes it's driven by the exhaust cam but its easy to line up again nothing scary there Smile
Posted 14th May 2013 at 19:43
its on an o-ring.
4556 05
DIAM 44X48-2
- INJECTION XU10J4RS
Its the same seal on the J4 and the XU diesels, and the DW8.
it's less than a quid so I wouldn't go bodging it with goop.
Posted 14th May 2013 at 19:44
spiky
ok cheers,
MY YouTube Videos'
spiky
will get one ordered, it's been like since i had the engine in 2007 so no rush to fix Smile
MY YouTube Videos'
Posted 14th May 2013 at 19:49
Less than a quid yes but means a trip to pug when you have plenty of decent goop around like me :p
Posted 14th May 2013 at 20:30
monty-69
Says the Peugeot "specialist". Shock
Posted 15th May 2013 at 13:29
I must admit, I was thinking the same...LOL
Posted 15th May 2013 at 13:59
beez_neez_gt
Everyone's a specialist until proven otherwise LOL
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 15th May 2013 at 14:26
consider proven otherwise then Wink
Posted 15th May 2013 at 14:39
This. Yes
Posted 15th May 2013 at 15:09
