https://www.youtube.com/watch?v=qQB5OERgCtY&feature=youtube_gdata_player
| Author | Subject: idle /running problems , help needed driving me mad |
mike rallye
Seasoned Pro Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
After putting a want section for some parts and replying back to the replies I had .I thought I put my video in this section .hoping someone would of had this fault, as i cant keep driving it like this.https://www.youtube.com/watch?v=qQB5OERgCtY&feature=youtube_gdata_player |
Rich E
It says the video is private.________________________________________ Rich |
mike rallye
Do you know how i change it? As i can view it ok Does it work know ,i changed a setting ? |
mike rallye
Well spend some time this evening after work ,and i have seemed to have fix the fault and all seems to be running good at the moment |
mike rallye
Well I havent completely sorted the problem it still doesnt idle right some days, regarding to what rich e said .that the breather pipe on icv should stall if I put my finger on the end is that right? As it doesnt stall but it idles spot on with my finger on the end as it is sucking my finger as in vacum .So I need helps and ideas of what to check next. |
7057sam
Seasoned Pro Location: Stowmarket,Suffolk Registered: 18 Apr 2009 Posts: 2,080 Status: Offline |
I actually have the same problem I first thought it was pas sensor but now think its mine icv breather filter.Does yours whistle? Maybe re route the pipe into the induction kit? ________________________________________ Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track ----Click this if you like rallyes Rallye dead Secret Team Astor... |
mike rallye
No mine doesnt whistle, I have tryed new icv valve to, and made no odd with the pas disconnected either. Am wounder if it could be airbox resistor? but woundering what other guys suggest to. Iwould need the new elbow pipe to fit the new breather pipe into it Were is the throttle body heater guys. ? |
stan_306gti6
The throttle body heater is a yellow device on the front of the throttle body, towards the radiator. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mike rallye
Cheers stan, was woundering if this would affect my idling issues? |
stan_306gti6
More than likely not to be honest. When you run a supercharger, that part gets removed and gives no idle issues. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mike rallye
Well I still got this fault which is driving me mad .some days it will idle and drive spot on amd other days it wont idle and undrivable .I have fitted new icv, tryed different lambda made no difference. Disconnect the pas and made no difference. Also fitted new map sensor Could the airbox resistor be at fault? otherwise what else should I look at guys? Comments and advice welcome |
Have you had it on a diagnostics machine? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mike rallye
No not yet, cant get to one |
