displaying posts 1 to 25 of 31
Author Subject: PT81's, BTCC inlet and management
JWP EFi
Turbo Legend!
looking for 200 bhp, i spoke to a specialist based in the south of england and was told this is very acheiveable
Anyone care to comment?
Posted 9th May 2013 at 21:20
"BTCC INLET" LOL.
maybe.
repost.
Posted 9th May 2013 at 21:21
JWP EFi
Turbo Legend!
I dont know much about N/A tuning but from what ive learned the 'BTCC' style inlet allows for more air flow. Apparantly the inlet was a cheat for the touring cars back in the day.
Posted 9th May 2013 at 21:27
"BTCC INLET" LOL.
maybe.
repost.
And that's funny because ?
JWP EFi
Turbo Legend!
bigbadbowen wrote:
"BTCC INLET" LOL.
maybe.
repost.
i wondered exact same
Posted 9th May 2013 at 21:28
Correct, but there is a very specific way to do this and it's not cheap No
JWP EFi
Turbo Legend!
care to enlighten me chris?
Posted 9th May 2013 at 21:29
It's how it's opened up and then remove all the trumpets from inside then put back together. It's done so you would never know it had been.
It costs about £300 to have done I think Dunno
Posted 9th May 2013 at 21:33
JWP EFi
Turbo Legend!
daveyboy did this not too long ago, 300 quid sounds quite fair given the ammount of labour involved but i do happen to know an engineer that is keen to learn about this malarky
Posted 9th May 2013 at 21:35
I think it's cut open along the seam then excess metal removed from within. It's then carefully put back together so as not to be obvious it's been done
Posted 9th May 2013 at 21:39
JWP EFi
Turbo Legend!
daveyboy's pics shows you all you need to know to know re how to do it
so the btcc 306 really was cheating then???
Posted 9th May 2013 at 21:41
eddy_gti6
Then you will want a different throttle body and air box Wink Also if your planning on pocketed pistons go for PT84's may aswell go all out Wink
Kent Cams
Speak to pete_rallye, he has the yellow one below Wink
Posted 9th May 2013 at 22:04
They all bend the rules dude Thumbs up
Posted 9th May 2013 at 22:08
JWP EFi
Turbo Legend!
eddy - 84's wont work with original valve gear, not for long anyway
bbb, there are a few cheats about...
anyway, is it really worth fitting a touring style inlet? dont mind doing it as long as i can actually feel the gains
Posted 9th May 2013 at 22:18
Ill say for a fact it doesn't work as a stand alone modification. It needs the modified or replacement pistons (preferably high comp) and decent cams to match.
Posted 9th May 2013 at 22:28
Would your southern England specialist be Brett Simms by the way? And if you want a manifold I'd be happy to make another.
Posted 9th May 2013 at 22:30
JWP EFi
Turbo Legend!
if i do this i will be pocketing my standard cast pistons to allow optimal timing of 81s, management wise i'm pretty much sorted. i have seen a coupe of people on here are a couple of ponies away from 200 brake so would like to think that with good ecu (and yes, proper mapping) i can crack my goal
Posted 9th May 2013 at 22:33
JWP EFi
Turbo Legend!
no. they specialise in pugs and carry out performance tuningUnsure
clues are there
Posted 9th May 2013 at 22:35
ahh that well known race and rally engine builder with many class wins and championships to their name...
Posted 9th May 2013 at 22:37
JWP EFi
Turbo Legend!
Wink i know
Posted 9th May 2013 at 22:38
Ah...I'll get my coat...
Posted 9th May 2013 at 22:46
JWP EFi
Turbo Legend!
really, that bad?
I'm assuming if mr Simms recommended touring inlet then it would be worth it, yes/no?
Posted 9th May 2013 at 22:49
Don't bother with PT 81s fit the 82s and get some Wossners under there. You'll need the extra compression to make high lift/long overlap cams work anyway, so do yourself a favour and don't skimp on the job.
Posted 9th May 2013 at 22:50
JWP EFi
Turbo Legend!
this summer's project is no longer car, its an engine
tbf, ive not looked into 82's, what are approx expected gains with afore mentioned mod's?..i hate that word
Posted 9th May 2013 at 22:57
Solid lifters for starters
Posted 9th May 2013 at 22:59
