Author Subject: Dimma with vts rack ram
pugheaven
I'm after a phase one vts rack and have been thinking....
Due to me running the wider track on the Dimma can I get away with using the vts ram apposed to the 6 one that restricts the amount of travel to avoid hitting the box?
Posted 9th May 2013 at 20:42
how much wider is a Dimma?
Posted 9th May 2013 at 20:56
pugheaven
Iirc 40mm longer arms and track rod extensions, 8" wide wheels?
Posted 9th May 2013 at 21:03
et0 arent they?
Posted 9th May 2013 at 21:07
pugheaven
Yep et0 so 4" from the hub face inboard plus the 40mm of extra track.
Not sure if that info helps lol fingers crossed you can work it out mathematically somehow Smile
Posted 9th May 2013 at 21:16
maybe.
the gearbox is 55mm longer than 5 speed unit, however I'm unsure how far away from 5 speed box the tyre is, I do know that the narrower 205 (same rack and hubs) will rub the end of the box with a 195 tyre as standard
pugheaven
I guess I will have to wait and see Sad just hoping I can use a phase 2 rack and pipe work with out swapping the ram or anything else over.
Posted 9th May 2013 at 21:20
I would hazzard a guess that it would be fine, not hard to make up a lock stop.
Posted 9th May 2013 at 21:22
pugheaven
To be honest I haven't even had a look at a rack yet so wouldn't know what to do to limit the travel, could it be as simple as applying a clamp around the ram piston? Or would it have to be a mechanical stop welded to the subframe to stop the ram extending to its fullest range?
Posted 9th May 2013 at 21:27
gilesy
I changed my ram for a std one (no second hand ones about and it was leaking everywhere) and even with new tyres on it only just rubbed the edge of the box so I would guess you'd be fine with wider track as the pivot point is further out unless you have monster truck tyres on
Posted 9th May 2013 at 22:28
birk
Mine was fine with a 5spd s16 rack.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 9th May 2013 at 22:53
pugheaven
Is the s16 rack the same amount of turn from lock to lock as the vts rack?
Posted 10th May 2013 at 11:52
no, about the same as a 6 less the limiting.
Posted 10th May 2013 at 12:13
birk
Well either way, my wheels are no where near my gearbox on full lock.
07889376885
Dan
Posted 10th May 2013 at 17:02
