Author Subject: Radio code
dasarich
Hi all , have got a CD player from a 106 ( 03) plate , but it is identical to the one that came out of my phase 3 6. Is there anyone who has the code disc that contains the radio codes
Posted 8th May 2013 at 17:20
mechanical_repairs
They are not done like that, you will need the original cars reg and the last eight of the chassis.
Carl
Posted 9th May 2013 at 20:52
dasarich
Cheers Carl , have got that as its the wife's car , is this a service you provide and if so how much ? The dealers here wanted £20.00 but for £34.99 I can buy a spanking new Philips from halfrauds ! So would go this route if too expensive
Posted 9th May 2013 at 21:36
mik
I did the same sums and ended up buying a nice new modern head unit.
Cherry Rallye SOLD
Posted 9th May 2013 at 21:58
mechanical_repairs
The supplying dealer of the car new will have it, if they do and you ask nicely chances are you will get it for free, if they don't have it they have to ring peugeot technical (they hold the details) and a cost is brought to the dealers, hence the cost to you.
I can get it but it still costs me the £20.
Carl
Posted 9th May 2013 at 22:38
smegal
There are some websites that can get the code. I did it once upon a time.
Ex SC-6
Now in a Megane R26
Posted 9th May 2013 at 22:53
dasarich
Cheers all, have fitted the one from the 6 for now
Posted 30th May 2013 at 20:02
birk
This method worked for me!
The label on the radio states
C6CBK0094099
C70000003214
Take the 3214
Add 1 to the first digit (1+3) = 4
Add 2 to the second digit (2+2) = 4
Add 3 to the third digit (3+1) = 4
Add 4 to the fourth digit (4+4) = 8
As you can only enter numbers 1 to 6 on the radio, for any numbers greater than 6, subtract 6 therefore the code to enter is 4442
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 30th May 2013 at 20:09
C6CBK0094099
C70000003214
Take the 3214
Not the radio being talked about as this is the sticker seen on one so make your method work...
Work the code out and I'll tell you if you are right.
Posted 30th May 2013 at 20:30
dasarich
Yet again mein fuhrer is correct , the code listed on my radio is the same as thugpuggins style . I believe yours is the older phase with which you could decode easily enough ! Many thanks again though
Posted 31st May 2013 at 19:53
