Author Subject: Discovering Vacuum Leak
rallyestyle
Afternoon chaps.
Whats the best way to discover a vacuum leak? Can of carb cleaner spraying around the vacuum lines?
Any other methods that are best for 6's / Rallyes?
Just Drive It
Posted 8th May 2013 at 15:04
ryangti6
Can of carb cleaner will do the trick if your leak is letting the engine draw in air, the revs should change when you hit the right spot.
If its on the pipes other than taking them off and inspecting them, then blocking one end and seeing if you can suck through it I'm not sure how else you could check them.
What makes you think you have a vacuum problem?
Ryan
Posted 8th May 2013 at 16:13
rallyestyle
I have a stuttering on idle/hesitation on acceleration issue. Have checked most things but although a visual inspection of the vacuum lines has not revealed anything i thought i best do a test of sorts before getting a diagnostics guy out
Just Drive It
Posted 9th May 2013 at 08:45
Map or throttle position sensors.
Posted 9th May 2013 at 10:46
rallyestyle
Pretty sure i have tried both but no joy No
Can't remeber if the map i used was a new one or not though Unsure
Just Drive It
Posted 9th May 2013 at 13:29
ryangti6
The rallye I had for a short while was hesitating on small throttle openings but fine otherwise. It failed the mot idle test so I swapped the lambda which seemed to cure it.
Ryan
Posted 9th May 2013 at 13:56
It is most likely a lambda problem. Yes
Posted 9th May 2013 at 14:27
rallyestyle
It happens with the lambda unplugged though so not so sure Unsure
I have a spare but i am dreading trying to get the old one off, seized on i reckon, talk about awkward Crazy
Just Drive It
Posted 10th May 2013 at 11:07
