Rallye-RNurburgring article
| Author | Subject: Spark plug socket size? |
braymond
Seasoned Pro Location: Brighton Registered: 20 Aug 2008 Posts: 1,163 Status: Offline |
stu
Seasoned Pro Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
16mm.I'm sure someone will correct me if I'm wrong though. |
braymond
stan_306gti6
16mm is correct. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
often called 10mm, as that's the thread size.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
beez_neez_gt
When getting a new socket for them then try get a magnet spark plug version type, will make changing them far easier.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
braymond
What's the appropriate torque for plugs? I've always thought finger tight + half a turn but I'm sure there's a something more precise..________________________________________ Rallye-RNurburgring article |
third of a turn IIRC says the side of the NGK box.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
beez_neez_gt
25 Nm 18 lbf to be pricise. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Just tighten till you feel the crush washer fully squished. Simple as that.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
armzs16 wrote: Just tighten till you feel the crush washer fully squished. Simple as that. with some guys lack of "feel" for how tight stuff should be, that's not a wise recommendation, ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
monkey tighten.________________________________________ 205 GTIXsara HDI |
Definitely not "FML Daniel has worked on this car before" tighten...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Depends if the plugs are new or not.If they are new, it's generally finger tight then half a turn to crush the washer. If they are used then a quarter of a turn as the washer will have already been crushed. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
Or as what a pro does is use a torque wrench.Doesnt the spark plug end have to be in at the right distance using the torque setting? Also as i do apply some copper grease around the top of threads so they dont get seized in etc. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
