Author Subject: Wheel alignment issue
renick
I bought a damaged Ph3 '6 a while back & is almost back on the road but has one problem I've yet to solve.
Damage was to the front right & I got it put on the rig at my local (very good) panel shop where they confirmed the chassis is straight (after a very slight tweak). The subframe doesn't appear to have any damage. I've replaced the track rod + end & balljoint but despite this I now run out of toe adjustment.
Has anyone come across a situation where the hub carrier or lower arm have been bent? They're pretty solid but I'm planning to swap them with those on my Ph2 to make sure that's not the issue.
Any thoughts on the problem would be appreciated.
306 Ph2 GTI-6
306 Ph3 GTI-6
106 S1 Rallye
205 GTI mi16
309 GTI mi16 track car
http://www.fastfrogs.co.nz
Posted 8th May 2013 at 03:11
yes, lower arms can bend easily, also could be a bent bottom of strut, and could also be wrong balljoint, non pas are shorter.
Posted 8th May 2013 at 09:15
Have had subframes bent before now as well.
Posted 8th May 2013 at 10:18
