Author Subject: PH1 & PH3 dash
JWP EFi
Turbo Legend!
The Phase 1 dash is the same as 2&3's isn't it??? A mate is due to drop my spare dash off to get flocked so just looking for a second opinion Smile
Posted 28th Apr 2013 at 21:36
Other than the airbags, if its ac or non ac and also the colour of the centre /bits like the dash light brightnesd wheel i believe so.
Posted 28th Apr 2013 at 22:11
JWP EFi
Turbo Legend!
its only the bare dash i'm talking about
Posted 28th Apr 2013 at 22:14
wiring looms are different and attached to the rear of the dash.
Posted 28th Apr 2013 at 22:15
JWP EFi
Turbo Legend!
hmm, dash removal/refitting is my worst feared job on these, so i want to fit a bare PH1 dash to a PH2 or possibly 3. other than re routing the loom will it fit straight in with later spec trim
Posted 28th Apr 2013 at 22:28
glovebox is thinner
Posted 29th Apr 2013 at 10:49
swiftyboi006
I think the answer your looking for is yes
Black p3 Love
Posted 29th Apr 2013 at 20:23
swiftyboi006
The main dash frame is the same its just things are routed differently along wuth air bags and glove box being different aswell
Black p3 Love
Posted 29th Apr 2013 at 20:24
JWP EFi
Turbo Legend!
i was 99% sure they were interchangeable just wanted to double check before i pay for flocking
Posted 29th Apr 2013 at 22:15
you'll have to do wiring alterations almost definitely, fog lights, speedo etc, I'm sure there will be a few other things
are you putting a p1 into higher or vice versa?
Posted 29th Apr 2013 at 22:21
JWP EFi
Turbo Legend!
phase 6 dash into a phase3. fog wiring not an issue, in fact whilst i'm swapping them i might just simplify the loom,got to be worth a few kg's
Posted 29th Apr 2013 at 23:33
pugheaven
I've been down this route before and its not worth the hassle hence why I sold my phase one flocked dash.
More relays on the phase 2/3, fuse box is different so you would have to cut out the old fuse and relay plastic and plastic weld it in.
A Rallye dash is your best bet if you want the phase 1 dash but again it depends if you have the aircon heater unit or just a heater unit!
Posted 5th May 2013 at 12:06
JWP EFi
Turbo Legend!
my car is an a/c model. only reason im flocking ph1 dash is because i had it already removed. think its already in process of being flocked so no backing out now
Posted 5th May 2013 at 15:20
pugheaven
Good luck then bud, I have a feeling your going to need it Smile
Posted 5th May 2013 at 18:03
JWP EFi
Turbo Legend!
Hmmm, having second thoughts now. I actually quite fancy removing the dash alltogother. Got to be worth 15 kg's along with binning heater assembly and sound deadening
Posted 5th May 2013 at 23:57
