Author Subject: Water coming in over the door seal
Kale
Had anyone else had problems with water pouring inside the car from underneath the door panel. It seems to come over the door seal but I'm not sure. It isn't much but it bugs me off. It has been doing this for a few years, never had the interest to look into it before. Is the door seal worn or does it come beneath the door card. I've removed the insulations (whatever they're called) under the door card several times but taped/glued 'em back on securely every time.
The door seals look quite worn though as they have been on there for 160k miles and 19 years.. LOL They're not broken or missing rubber, just "dented" in the middle and not so puffed up as they probably should as new.. Dunno I remember removing the connecting piece "hose" between the seal where it goes together. Don't ask why, because it was like 10 years ago. Maybe it had something to do with the seal filling up with water back then.. Hasn't been doing it since tho'
306 S16 "Peugeot Sport GrpN" '94, 405 Mi16 "OEM+" '89, 605 SV24 "Executive Express" '91
Posted 25th Apr 2013 at 15:04
mellowr1
Mine Used To Do This.it Filled The Seal Then Ran Into The Car.
I Rectified It By Buying A New foam Seal That Covers The Speaker Area Of The Door Panel.It Was About £30 But Instantly Stopped My Car Filling With Water Whenever It rainedThumbs up
Posted 25th Apr 2013 at 15:58
Kale
Where did you buy it?
Posted 25th Apr 2013 at 16:40
mellowr1
Local Peugeot dealerThumbs up
Posted 25th Apr 2013 at 16:51
Kale
Will it drip if I cut the speaker hole, I guess not..?
You might be on to something, it started dripping after I added some sound deadening for a few kilos and made the car much quieter.. And foolishly removed it then even though I never really had to. After I changed my electric windows motors to new ones it has been pouring even more water inside..
Posted 25th Apr 2013 at 17:04
mik
Definitely sounds like a problem with the membrane behind the door card that keeps the water out of the car.
The cause could be a combination of more than one thing - e.g. the plastic membrane behind the door card is not keeping the water out, the soundproofing might be stopping the water getting out the bottom of the door (water is supposed to run through the door and out the drain holes in the bottom), or the door seals could be past their best as rubber shrinks a bit over time.
Try taking the door card off and then pour pater down the outside of the door so you can see it happening?
Check the plastic membrane's fit around the door speakers and whether the soundproofing has changed the water path, and finally I would spray silicone or similar onto all the rubber seals once per day for a week and it might make the seals perform a bit better.
Cherry Rallye SOLD
Posted 25th Apr 2013 at 17:15
Kale
I really hate getting silicone onto the paintwork. B*tch to remove. Maybe I'll just buy new seals.. But first I'll try those membranes.
Posted 25th Apr 2013 at 17:39
anth
It will be the membrane, every car will leak without them.
Posted 26th Apr 2013 at 07:25
mellowr1
if you do not have the plastic sheet that fits over the speaker hole and the foam seal the water drips onto the top of the speaker area on the door card,then onto the door and it runs onto the rubber door seal instead of into the bottom of the doorThumbs up
Posted 26th Apr 2013 at 08:34
Kale
I have the membrane installed, it's just pretty much fubar Big grin Taped from pieces and glued in place, I guess it's my problem.. It has been removed and installed back many times and every time it has taken some damage and has been ripped somewhere.
So if I push out the piece that is meant to come off under the speaker (when I buy the new membranes), it will leak from there? Speakers will sound sh*tty if they can't breathe inside the door Sad
Posted 26th Apr 2013 at 12:07
mellowr1
No,Its Perforated.Just Tear The Bottom Line Of Perforation,Which You Will Need To Do Anyway To Connect Speaker Lead upThumbs up Up
Posted 26th Apr 2013 at 12:57
Kale
Of course, the wiring, how stupid of me Big grin Didn't even think about it.
Posted 26th Apr 2013 at 19:21
