Author Subject: light rattle at 3000 rpm
bas_306gti
Hi,
I’ve got a light rattling noise coming from the engine bay when driving, at approx. 3000 rpm.
The rattling noise is only there when driving, not if the car stands still (at idle or 3000 rpm)
If when driving, the revs go up or down 3000 rpm the noise disappears.
There’s no contact between exhaust and chassis.
Anybody got a clue?
Posted 18th Apr 2013 at 20:59
RetroPug
Just a thought, but check whether or not it's the heatshield behind the engine that's rattling?
Posted 18th Apr 2013 at 21:19
bas_306gti
Thanks but already checked that, all four bolts are tightened.
Posted 18th Apr 2013 at 21:31
beez_neez_gt
Either the cat on its way out or the heat sheild under the car.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 18th Apr 2013 at 21:43
bas_306gti
Cat has done 190.000 miles....
Posted 19th Apr 2013 at 06:12
So?
Posted 19th Apr 2013 at 07:31
beez_neez_gt
It doesnt matter how old or how many miles something has done things can go anytime, my cat did the same at 60k ish. I would say its most likely the cat is loose inside the casing somewhere, give it a few hits with the irish screwdriver and see if it rattles then, then you can rule that out or not.
Pug fee`ver,
Posted 19th Apr 2013 at 10:16
bas_306gti
The cat is probably on the end of it's lifespan, 190K miles is quite a lot (what is normal with a OE cat??)
There's also some sort of 'blowing' sound coming from the lower exhaust when shifting at higher revs and it's not because of a exhaust leak so I think is antoher reason the cat is on it's way out.
Posted 19th Apr 2013 at 14:00
beez_neez_gt
Yep will be cat then, try get an OE one as they will last much longer than the cheap ones. I got a decent used one.
Pug fee`ver,
Posted 19th Apr 2013 at 14:21
birk
Just chop it out.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th Apr 2013 at 14:29
aaron6
The blowing will be the fire ring gasket where the cat joins the down pipe. My one makes a zinging noise at 3800rpm. Must be a heat shield I think. Get the cats efficiency checked before plumping for a new one. Wink
Posted 19th Apr 2013 at 16:55
beez_neez_gt
Sure after testing it himself with a hammer, then no need to spend any money at all. My one that went was a cheapo replacemnt done before i purchaced the car, when taken off rattled by hand.
Pug fee`ver,
Posted 19th Apr 2013 at 18:16
