Author Subject: head
fatlapit
Needed a good head as my belts just snapped
Posted 14th Apr 2013 at 18:41
You would be better off with head and block as bottom ends tend to go not long after a belt snap Yes
Posted 14th Apr 2013 at 18:58
fatlapit
Belts only done 2k
Posted 14th Apr 2013 at 19:15
mechanical_repairs
Never seen that issue much on these engines if at all.
Carl
Posted 14th Apr 2013 at 20:49
JWP EFi
Turbo Legend!
what brand of belt was fitted prior to snap
Posted 14th Apr 2013 at 21:00
fatlapit
Gates. upon further inspection tge idler has snapped off
Posted 14th Apr 2013 at 21:57
ryangti6
I've got a good complete head.
Pm me if interested
Ryan
Posted 14th Apr 2013 at 22:03
JWP EFi
Turbo Legend!
hmm, thats a strange one, silly question but was the bolt properly tightened?
Posted 14th Apr 2013 at 22:25
fatlapit
was torqued up using a snap on digital wrench as per autodata
Posted 14th Apr 2013 at 22:27
Carl
Well it's a well known fact young man seen it happen lots of times Yes
Posted 14th Apr 2013 at 22:31
Then you will defo need a bottom end now then Dunno
Posted 14th Apr 2013 at 22:32
JWP EFi
Turbo Legend!
the broken bolt could be removed, it won't be bottomed out in the hole so should be fairly straight forward to undo it, providing it is drilled bang on centre then use a stud extractor...been here, done, this a few times. Easy out is your best friend
Posted 14th Apr 2013 at 22:36
fatlapit
ive got a spare bottom end but the bolt will be easy to get out
Posted 14th Apr 2013 at 22:38
As long as the bock is not damaged Yes
Posted 14th Apr 2013 at 22:40
JWP EFi
Turbo Legend!
true. you may be lucky to find theres enough of the stud left exposed, so you could use vice grips to undo it
Posted 14th Apr 2013 at 22:41
fatlapit
I hope so, but now im gonna have to check frog over!!
Posted 14th Apr 2013 at 22:47
JWP EFi
Turbo Legend!
if your careful about it, you will get it out. Although i would be puzzled as to why did it happen in the first place? Did your belt kit come with a new bolt?
Posted 14th Apr 2013 at 22:52
fatlapit
yeah mate I got everything for it I cant believe its happened tbh, I wasn't even honing it was only sitting at 4k cruising in 6th
Posted 14th Apr 2013 at 23:07
JWP EFi
Turbo Legend!
...4k at 60, that heads well and truly knackered then. normally i would blame incorrect torque tighten but if you've done it right then it must be faulty bolt. Unlucky.
Posted 14th Apr 2013 at 23:10
fatlapit
then surely gates are responsible for it then
Posted 14th Apr 2013 at 23:28
JWP EFi
Turbo Legend!
i know that Dayco are offering money towards repairs should one of their kits f**k up, tbh i doubt you will get any help here though.
Posted 14th Apr 2013 at 23:34
fatlapit
dunno I can ask
Posted 14th Apr 2013 at 23:36
